Question about Maytag SkyBox MBV1976A Beverage Dispenser
Not cold enough. Unit worked fine before i moved it.
Now my evaporator fan wont come on.
Place a thermometer in your unit and get a good temperature reading for the current temperature. Unplug your unit and take the cover off the thermostat and remove the knob. Take the nut holding the thermostat to the plastic holder off. Thermostats vary but somewhere on the thermostat there will be a small screw or possibly allen socket. I forget which way I turned mine but turn the screw about a half a turn and then close the unit up and check the temperature again (overnight preferably). If it went in the right direction you're in good shape. If not, turn it back the same distance past the first setting and check it again. This resets the operating range of your thermostat.
Posted on Mar 04, 2009
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
The freezer is not enough cold, i check the defrost sensor, temperature sensor and its are ok, but the evaporator fan motor is not working... why? i check this fan too and is ok. Now what can i do??
It could be on automatic defrost mode, let it run for a while and see if it gets cold enough, also if you have the freezer to full and stuff near the cooling fan in the freezer, the freezer can not circulate to get cold.
Mar 01, 2015 | Refrigerators
Refrigerator side is not cold enough the Freezer side is fine, is there a fan that blowes the air from freezer into refrigerator and where is it located
Not necessarily. There may be 2 compressors on the back of the unit, one for each side. If no,t the fan will blow cold air from the freezer's evaporator into the fridge side and will be between the two.
May 10, 2012 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Top of freezer is fine but the bottom isn't as
Sounds like your evaporator fan is not doing its job. The purpose of this fan is to move cold air from the evaporator coil (behind the lining of the unit) to the rest of the freezer and to the refrigerator.
The fan should be behind an access plate at the top of the freezer compartment. If it is running, you should be able to hear it. If you don't hear it, open the access plate and look at it. If the fan is not turning, you will need to replace the fan motor.
Oct 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator wont stay cold.Freezer works fine,no frost buildup
i replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 27, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Cooling problems
Did you make sure the evaporator fan is working? I would check that and also make sure the evaporator is not all iced up. If it is iced you have a defrost problem and not with the sealed system. so check that out and get back if you can. Thanks
Jul 15, 2007 | GE GTS16BBSL Top Freezer Refrigerator
Not getting cold
fan only comes on when evaporator is down to temp. the fact it is not coming on points to a compressor fault ie evap not getting cold enough
Jun 10, 2007 | Amana ASD 2624 Side by Side Refrigerator
Maytag SkyBox MBV1976A Beverage Dispenser Logo
194 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
