Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 gas range, oven dial doesn't have "lite"?
On the GE XL44 gas range, oven dial doesn't have "lite" on it like the stove top dials do. Does it light automatically when you turn it on to any temperature? New user to gas cooking, don't have the manual.
  • Anonymous Mar 29, 2014
    oven will not come on self cleaning lite just blinks when you turn it on it lites in self cleaning then switch it to regular oven it goes out wife cleaned under it with drawer out then put back drawer then it messed up think she could of knocked something loose
  • GE Master
  • 3,361 Answers
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Posted on Feb 27, 2009
  • Robert HensonSr Nov 24, 2013
    With the control in the "off" position, the oven turns on and off by it self, how do I fix it?
SOURCE:
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
No gas to the oven. Ignitor is lit. Top burners work properly.
I have the same problem. The burners work but not the oven. Ours started beeping with a FO code. The tech came out and said the control panel is bad and needs to be replaced. He also said ALOT of people are having the same problem and they might do some kind of recall down the road but for know we have to wait til Jan to get our part to fix it. Boo
Dec 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE XL44 gas stove the oven will not stay lite why?
That's bad. Sounds like the burner is dirty.
and the gas belive it or not is blowing the polit out it hit it so fast. The gas can't go in the burner. There should be two screws that hold it in place take it off and clean. See if that will work. Let me know.
Ken
Sep 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
562 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
