Question about Lexmark X500n Color Laser All-in-One Printer
Source for 24V DC 5x5 x1cm 3-wire fan?
This is the CPU cooling fan used in Lexmark X500n and X502n multi-function units. Lexmark parts dep't says they can only sell me the controller board that includes the fan for $1200. I'd really like to find a source for just the fan. Thanks
  • ftcnet-ca Mar 19, 2009
    we're in western Canada.
    The fan markings show:
    Y.S. Tech
    DC Brushless Fan
    FD245010MB
    DC 24V 0.10A
    made in china
    5 x 5 x 1 cm
    3-wire connector
  • ftcnet-ca Mar 25, 2009
    The above offered 'solutions' are not. SparePartsWarehouse can't supply that fan. eBay lists lots of fans, but none that meet the required specs (so far).
  • 4 Answers
Go to www.cypower.com we have these fans on order. Just put in FD245010MB in the part number search and click add to cart. We have heard there is a 12 week lead time right now but we will get them in.
Posted on Apr 23, 2009
  • 523 Answers
Where r u located?
Posted on Mar 19, 2009
  • Lexmark Master
  • 19,396 Answers
Is it a x500n?
Posted on Mar 02, 2009
  • Lexmark Master
  • 13,433 Answers
Do you have the old fan? could you get me details from it? does it have a part number?
  • Ekse Mar 02, 2009
    HAve a look here, on ebay We will definitely find you a fan instead of paying 1,2k for just a darn fan.
    Its a generic computer fan with + - and RPM sensor.
    You haven't included your location at all. Where are you located?
    Do you think you could fit in a bigger one if we can't locate a similiar one? The part number would be really helpful. I'm still looking around.
    we have some fans here
    http://www.maplin.co.uk/Search.aspx?crit...
    this one maybe too big click here But I suggest you contact the sellers who sell fans on ebay, im sure someone will have one for you.
    So do you have a model on the fan? could look for a exact replacement. So far only similiar ones.
    I would appriciate that you accept my solution so we can communicate better.
    Thanks,
    Ekse
Lexmark x500n keeps on saying CPU FAN LOCKED on the display.
HI there please reset the printer and turn of for 10 minutes. After that turn on try. Let em know the result.
Feb 15, 2011 | Lexmark X500n Color Laser All-in-One...
CPU fan locked
Wow, after hours of searching I found the right connectors for the fan since it comes with bare wires when ordered from cypower.com.  (The fan to order is a 24v DC Y.S. Tech FD245010MB.)  The connectors are from JST America and can be ordered from www.digikey.com.
Part 455-1126-ND (housing that takes pins spaced 2mm apart)
Part 455-2148-1-ND (pins)
You have to order at least 10 housings and 100 pins but all of that costs about $2.50.
You can also order the crimp tool but that costs $1,300.  I'll just use a needle nose pliers.
Oct 20, 2009 | Lexmark X502N All-In-One Laser Printer
Error message cpu fan locked lexmark x502n
you have to replace the fan.
You can order it here: henke.harald@web.de
Oct 11, 2009 | Lexmark X502N All-In-One Laser Printer
How do you change the fan on a Lexmark x502n?
Yes sir, Make sure its the same Voltage/Amperage, connector style, hole configuration where it screws into the frame. Looks like on this printer the fan is on the right side? Just a guess. If so, power off the printer, remove the cover and remember how the fan looks now so you can put it on the same way. I mean make sure of the air direction, etc. A 2 wire connector that you can find by following the wires to the engine board and remember, again, where and how it was plugged in. Also, if you can download the lexmark service manual PDF, its pretty clear as far as locations and part numbers and such.
Sep 25, 2009 | Lexmark X502N All-In-One Laser Printer
WARINING CPU FAN locked on Lexmark X502N
Sounds like this will need to be looked at by a qualified service technician. You may want to contact Lexmark Customer Support. If your printer is still under warranty it should probably be covered.
Jan 30, 2009 | Lexmark X502N All-In-One Laser Printer
Double side priting in lexmark X502
in Lexmark X502n you can not do a duplex print as in print both sides which is actually a big surprise because overall its an amazing printer.
Go on this website and at the bottom you'll see that it has no duplex printing:
http://www.lexmark.com/lexmark/product/home/735/0,6970,204816596_653293760_1043815135_en,00.html?tabId=1
Jan 21, 2009 | Lexmark X500n Color Laser All-in-One...
Warning: CPU Fan is Lock in lexmark X502
www.cypower.com has these fans on order and will be available shortly to be ordered on their website. Just enter FD245010MB into the part number search.
Jan 15, 2009 | Lexmark X500n Color Laser All-in-One...
Warning: CPU Fan is Locked!
you have tor replace the fan.
Order here: henke.harald@web.de
Jan 15, 2009 | Lexmark X502N All-In-One Laser Printer
Warning: CPU Fan is LOCKED -- Lexmark X500n printer
I fixed this in 12 minutes. I took the fan out, lubed it up with a high-tech petroleum based lube and freed up the fan. Reinstalled and no more error message. We ordered a new one so when this fails, we'll be ready. It seems that moisture got into the axle and corroded it and caused it to lock up.
Jan 06, 2009 | Lexmark X500n Color Laser All-in-One...
Lexmark X500n Color Laser All-in-One Printer Logo
1,953 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
