Question about Evesham Computers & Internet
No connection to internet
Have got a message saying no network in the area yet my main computer has wireless on so i should be able to pick that wireless up but nothing
  • Evesham Master
  • 32,281 Answers
It appears that either the wireless driver is not installed or not configured on your laptop. If you have already installed the wireless driver then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Posted on Feb 27, 2009
Satellite p35 will not go to wireless
Might not have a wireless card installed ??
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop.
However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings."
This will give you options for modifying how you connect to the Internet.
Select "Connect to a Network" or "Show Network Status and Tasks."
Both selections will show you whether you are disconnected from the wireless network.
Select "Manage Network Connections."
This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection.
Engage the wireless connection.
Turn your wireless switch to "On," then right-click on the wireless network connection.
Select "Connect/Disconnect."
Wait for the IP address acquisition.
It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address.
When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength.
Launch your favorite browser to access the Internet using the wireless connection.
http://forums.computers.toshiba-europe.com/forums/thread.jspa?threadID=18365
Aug 25, 2013 | Computers & Internet
I have a Dell Latitude D600. I can connect to the internet if my computer is plugged directly into my modem. When I disconnect from the modem and try to access the internet using wireless, I can not...
Your computer may be picking up the wireless networks in your area including yours but you still require to configure your computer to the router for which you will require to go through the manual which came along with the router/modem. If you are a computer savy man you can do it yourself otherwise you will require services of technical person.
Feb 11, 2011 | Dell Latitude D600 Notebook
My dell inspiron e1505 tells me that it cannot pick up wireless networks. My computer was picking up wireless earlier today in front half of house. we extended the signal via ethernet cord and plugged in...
Depends apon the signal and how you have the computer settings some of the older computers have programs where differant places will not be picked up !
Did you check your internet options in your control panel?
1.Check your internet options and see if your lan settings have a check mark in the top box for lan atuomatic detect settings click ok then your internet should pick up ..... if you are still haveing prombelms please let me know ... Lala linda
has a check mark on the top box so there is a
Dec 24, 2009 | Dell Inspiron 1501 Notebook
My computer was wireless then one day when i try to connect it says no wireless networks in range. my wireless button is on but i still can't connect how can i fix this problem
maybe theres a problem in the wireless network that you are connecting to, that why your computer detected no wireless connection in range if there no wireless network to connect to you will get this message there nothing wrong with the adapter or you are far away for the computer to pick up the signal its either way
Nov 20, 2009 | Computers & Internet
Toshiba portege A600 notebook. wireless
unless you have a wireless router in your home; the msg "windows cannot find any wireless networks"
means any network in your area is too far away, or has a signal so weak your laptop is not picking it up as a viable source.
visit . www.filehippo.com and DL a file called Ccleaner. Run this program - it will clean all your internet caches and junk files, then run the registry cleaner. Reboot.
This can keep you from connecting.
Also try moving to different areas in your home and refreshing your wireless search.
if you are worried your wireless card may not be working properly, take it to a place like mcdonalds, or anywhere that has free wi-fi offered. if you still can not pick up a signal there you have narrowed it down to your wireless adapter.
you can also try this little program. Easy Wi-fi radar found here
Sep 17, 2009 | Toshiba PortegeA600-S2201 Notebook
Internet explorer won't open
when it says connected it means to the router, open up internet explorer>tools>internet options>connections tab and tick never dial a connection, or if it's already greyed out it's ok.
Assuming you have run the wireless network connection wizard first to set up the connection, if not it's in network connections and select new wireless connection or set up a wireless network.
Sep 24, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Sierra aircard 875u connect to Playstation 3
Actually, screw sending me the message. It would probably help more people if I just posted it in the forums.
I have a Verizon Wireless Mobile Broadband card plugged into my laptop because no one in my house has a desktop and we never bothered around with WiFi. I assume this aircard you speak of is similar to mine.
First, connect to the internet with your card. For me there's an application I have to run where I basically just open the app and click Connect. If you have XP (which I really hope you do because I haven't tried this on any other OS) open your Network Connections menu. This can either be done by opening the "Start" menu, highlighting "Connect to" and clicking "Show all connections", or by opening the Control Panel from the Start menu and selecting "Network Connections".
In the Network Connections menu, find your current connection. It'll be the one that says "Connected" in gray letters under the title. I don't know if they all are, but for some reason mine was under the Dial-Up category on the list. Next, on the same menu, look for the "LAN or High-Speed Internet" category. You should have a setting there called "Local Area Connection". I have two. You want the one that doesn't say anything about WWAN or Wireless. It should say something about your ethernet card if you leave the mouse cursor hovering over it.
Now that you've identified both settings, right click the first one you found (the one that says "Connected") and click "Properties". Once that menu opens, click the "Advanced" tab. Check the box under "Internet Connection Sharing" that says "Allow other network users to connect through this computer's internet connection." In the "Home Network Connection" box, type the name of the second connection you found in the previous step (the one that uses your ethernet card). On some computers, instead of allowing you to type anything, that box will drop down and show a list of all your connections. Either way, you know which to pick. Click "OK", and fire up your PS3.
Now, at this point I plugged one end of an ethernet cord in my PS3 and the other into my laptop. Your computer might say something to let you know it has established a Local Area Connection. Log in to any Playstation Network registered profile on your PS3 and open Network Settings under the Settings tab. Go to "Internet Connections Settings". I was able to click "Easy" and my PS3 did all the work from there.
Jul 16, 2008 | Computers & Internet
Laptop problems
Does this mean that its the laptop that can't get a wireless connection? Just want to clarify before giving out more steps that you can try.
Jul 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Lost internet on my desktop which uses wireless lan card and antenna to connect to linksys wireless g
Just a question, did your girlfriend accidentally kick your computer off the network by accident?
Mar 23, 2008 | Linksys Wireless-G Broadband Router
Internet switches off
First you must be using a wireless connection, if this is so reinstall the drivers for the device. If you are using a hard wired network connection, you can go into device manager and disable the wireless network. In any event the problem is the drivers are either not installed or the wrong drivers are installed for the wireless network. BPCS
Oct 10, 2007 | HP Compaq nx9030 Notebook
Computers & Internet Logo
372 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
