Question about Coleman Powermate Subaru 5000W Portable Generator
COLEMAN powermate 5000 generator w/a Subaru engine
Start up good run for 20 to30 minute then die out. Then I start it up and it will run for 15 or 20 minute and die out . It will keep doneing this.
Check the vent in the fuel cap to make sure its free to breath. It could be creating a vaccume in there and starveing for fuel. Maybe run it with the gas cap off and see if the problem gos away.
Posted on May 06, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
2001 Honda Civic car starts and runs fine ,after turning off ignition car would not crank or start only after 20 to30 minutes car would crank and start
Hi there I am technical mechanical and electronic engineer mechanic it need a new ignition switch or ignition lock n key
Oct 25, 2015 | 2001 Honda Civic
Why does my klr die after 15 to 20 minutes ? I HAVE A 2008 KLR WITH 15000 MILES ON IT . This year it started dieing after about 10 miles. First it misses a little then more the longer it runs before...
possible block in gas tank vent?? try cracking the cap a bit when the issue happens. if it keeps running you may need a new gas cap. go with the easy stuff first...always
Jun 27, 2017 | 2008 kawasaki KLR 650
2005 seadoo jetski wake
Check your exaust hose. Mine came loose inside the engine compartment and it caused the same problem. Would run great for a while, then just die or start sputtering like it was missing or the plugs were bad. After I let it sit for a while it would start up fine, run great for about 15 mins, then have the same problem.
Jun 20, 2013 | Boating
My car will start up and run for a good 10 to 20 minutes but then just shut off. After I waiting about another 10 to 20 minutes it will start up again. My lights still stay on when it dies so I am not...
Sounds like you are losing fuel pressure or the ignition module is shutting down when it gets hot. Check for spark when the car is in the no start condition. If spark is ok then install a fuel pressure tester and let car run. When it dies the pressure should be less than 15 psi. You may need a mechanic for this. Best possibility is that you will need a new fuel pump or ignition module.
Aug 30, 2011 | Hyundai Accent Cars & Trucks
My powermate 5000 with subaru engine will run anywhere from 30-60 minutes and shut down. One light pull to the pull start and it runs great for another 30-60 minutes. Never a problem to start it back up...
There is debri or dirt in gas tank and eventually it gets sucked up and clogs the screen filter on the end of gas line. Drain gas tank and flush out a few times. let dry and put new gas in it. check your gas can, if it is metal, it may have rust in the bottom of it and it goes in the gas tank and clogs screen, make sure you have a clean gas can that you use to fill the generator.
Aug 25, 2011 | Coleman Powermate Subaru 5000W Portable...
Coleman Powermate Subaru 5000W Portable Generator Logo
1,078 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
