Question about JVC AV-65WP74 Rear Projection Television
Av-56wp74 transported unit abou 2 miles, when i set up at new location the red was out of focus. i imagaine we hit a bump in the road. anyway, i tried auto convergence and also manual. all other colors lined up except red. still won't line up. got any ideas? thanks, bill.
  • 1,056 Answers
Try unplugging the wires leading to the convergence board, then plugging them back in. Tap the back of the red tube lightly, sometimes all there is a short inside the tube which is usually indicated by out of focus picture. Don't turn any adjustment inside the TV because it takes special equipment to adjust them back again, and these equipment are not cheap. If everything I posted here don't help, just use it for a while see if it goes back to normal on its own. Then decide to take it to a get fixed. Choosing the right shop is important. Preferably onces that specialize on big screen. Because I have worked in a TV shop before, and the procedure for them is very diffrent, and projection screen is much harder to fix than a regular television.This is one reason why it cost more to fix them. The shop I worked in charge anywhere from 200-over 400 dollars to fix a big screen, and to be honest with you most of the time another problem arise after that. Unless it is a HD projector, it is not worth paying a lump sum of money to get it fixed.
Posted on Jun 27, 2009
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
We went to auto focus on our tv. It shook wildly the when the picture came back the picture is bent. When looking inside the tv the green and red are being projected bent at the top and bottom. Please...
You need to replace the convergence IC stk392 -110...2 resistors and a fuse. located in the deflection board of your tv and after you can press auto focus and the picture will be normal.
Dec 18, 2010 | JVC AV-56WP74 56" Rear Projection...
Convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 06, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC I'Art AV-56wp74
A repair facility will charge 400 to 600.00 for the repair. Or you can repair it yourself if you can solder. As both convergence ICs need to be replaced. They are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jun 15, 2008 | JVC AV-56WP74 56" Rear Projection...
Help with jvc projection
you will need toreplace both convergence Ics they are STK392-110 ICs you can get replacement ICs at the following link with instalation instructions.
Jun 07, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 self check question
Each picture tube (red,green,blue) has a magnifying lens assy that sits on top. On each lens assy is a manual focus adjustment with a wing nut that tightens it. The image bounces onto the mirror and shoots it onto the front screen. If you're not a technician then I don't advise you to do this adjustment. You could touch something in the high voltage by accident.
C-Dog
Feb 11, 2008 | JVC AV-56WP74 56" Rear Projection...
After replacing stk392-110 convergence chips
behind your front panel is two rows of small black knobs that adjust the lamps brightness and focus. a phillips screwdriver might be needed to turn them. you need to adjust the red guns focus.
Feb 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Double vision On JVC AV-56WP74 56
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Jun 17, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74
sounds like a power supply7 problem such as a power regulator is bad or maybe the Horizonbtal deflection cu8rcuity is defective. sounds like something if you ask me? should be taken care of by the pros??? Im sorry not being able to assist you better but these sets have hundreds of volts nin them and shoulnt be played with by an unauthoized service company.. Good Luck
May 19, 2006 | JVC AV-56WP74 56" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
124 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
