Question about Lexmark C533DN InkJet Printer
Printer and Computer refuse to recognize each other. Have reainstalledd several times and still get there is no connection. Have even replaced cable but still no luck Printer is Lexmark x2650 Am running windows xp, service pack 3.
  • lynthepin Mar 30, 2009
    I have X3580 and have now lost communication betwen my laptop and printer. Have uninstalled and reinstalled - but still not communicating.
  • 54 Answers
Have you installed the windows drivers (not Mac)
Posted on Feb 27, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
My computer doesn't recognize my printer
It's possible that the problem is with the USB port on the printer. If you have a router, you can try to connect your printer using an ethernet cable so you won't have to configure your printer using a USB cable.
Once you have connected the printer using an ethernet cable, proceed with the installation in your computer and choose ethernet as the connection type. It should automatically find the printer on your network.
Dec 08, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Printer problem
Sounds like a hardware problem. Try connecting the printer to a different computer (plug and play) and then install the software. Try a different cable.
Silly question but is power getting to the printer?
Feb 11, 2010 | Epson Stylus C86 InkJet Printer
Refuses to recognize ink cartridges
Apologies for not responding earlier, forgot all about it. Solved problem by switching printer on and off many times. It eventually recognized cartridges. Now leave it switched on.
Jan 07, 2010 | Epson Office Equipment & Supplies
Printer USB Cable un recognized DCP150C
You need to isolate the problem. You tried using multiple cables and reinstalled the printer driver several times, but you never mentioned that you tried connecting the printer into another computer. What if the problem is the USB port of the computer and not the printer cable?
Try connecting and installing the problem printer into different computer for testing purpose only. If it work, then the problem is the USB port of the computer. To fix this, try updating the USB driver of your computer.
If same problem occurs using another computer, then you need to contact the manufacturer of your printer. I've heard this problem before and I don't have an update if there's a fix with it.
Have a great day!
Oct 01, 2009 | Brother Office Equipment & Supplies
My printer doesn't work even after I downloaded disk to computer. It is indicating my printer isn't connected.
Aug 17, 2009 | Office Equipment & Supplies
Windows XP SP3 will not recognize the printer is connected.
It could be the cable, but most likly it is a damaged driver. try uninstalling the printer and all the drivers then reboot and resinstall it. You could also run "sfc /scannow" to see if any system files are damaged.
Jul 11, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Dell photo printer 720
NO u just need first to UNISTALL driver then restart pc and install again from device menager not from setup
Oct 12, 2007 | Dell Inkjet 720 Printer
Lexmark C533DN InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
