Hello, recently changed the video card to my TV Westinghouse LTV-32w6 HD model, because it appeared vertical bands of white and red, after changing the card now, the tv turned on normally but when I use the remote control only because the key on / off, I do not see the menu on the screen. Please if I can help solve this problem? thanks Francisco
  • 1 more comment
  • conchetinna Feb 27, 2009
    yes the same card
    I wanted to know the solution to the problem is my tv, please do not stop responding,
    thanks Francisco ...
  • conchetinna Mar 04, 2009
    hello, please return my money to my card, I have not received an answer to my problem with my Westinghouse TV.
    Thanks
    Francisco
    Brigadier General:
  • 8,619 Answers
Hi!
Are the other functions on remote working fine. If yes, then please check for any loose wires inside the tv as replacing the card might have resulted in a faulty connection.
And if you can access other functions on the remote then your remote has gone bad.
Please revert for further clarification.
Posted on Feb 27, 2009
  • Rylee Smith
    Rylee Smith Feb 27, 2009
    Are other functions on your remote working?
    Can you acces the menu from the front panel of yout TV set?
    Please revert for further clarifications.
  • 10,594 Answers
Do you see Menu if press button on TV?
Please check connectors what you hooked while replacing video card.
    Genius:
  • 1,269 Answers
Make sure you installed the same model of video card that was installed.
  • 19,396 Answers
Do a reset to factory using service menu, refer to the servide manual.
  • Ginko
    Ginko Feb 27, 2009
    Try doing a reset using TV service menu, this should reset the TV option, and will exclude the eventuality that this is a setting problem.
    If the problem persists afterward , then contact the part seller, the new video card may be slightly defective.
Why doesn't it stay on channel?
Gustav, Try factory reset, to get to the Setup Wizard. With the TV on press the menu button on your remote. While the menu is displayed press the 0 button four times. This should bring up a new menu with factory reset as an option.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.hdtvsolutions.com/pdf/27w7_32w6_37w2uMan.pdf
Westinghouse LTV 32w6 User Manual
How do you factory reset Westinghouse lcd tv AskReddit
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/678671-new-offical-westinghouse-ltv-27w7-ltv-32w6-ltv-37w2-thread-87.html
Mar 12, 2016 | Westinghouse LTV32W6HD 32 in. LCD...
Antenna not working anymore?
talk with a tv technician as to the capabilities of the tv set but you may need a better outdoor antenna if the signal has changed from am to digital or fm in your viewing area
Jan 20, 2016 | Westinghouse Televison & Video
Vertical color lines wont stop running while audio is good.
Westinghouse SK-32H240S Problems Anyone? - AVS Forum ' Home ...
www.avsforum.com/.../1143881-westinghouse-sk-32h240s-problems-an...
May 2, 2009 - 30 posts - ‎18 authors
I have owned my Westinghouse SK-32H240s for about 18 months now, and I ... Youwon't be certain if you are getting the right firmware or the complete firmware. .....makes it stop for a while, the same as it may with a weak antenna signal. .... would just go nuts and display a bunch of colored bars vertically.
Roku Forums • View topic - Westinghouse LTV-32W1 HDMI problems
forums.roku.com/viewtopic.php?f=28&t=27628
Apr 28, 2010 - 15 posts - ‎8 authors
I have a Roku HD box and a Westinghouse LTV-32W1 tv. ... Any idea on why it won'tconnect to the roku correctly? ... This does nothing to stop evil people from stealing movies, but does make ... but it is just a bunch of lines and colors all stretched every way. .... all running wireless on a actiontec C2000A.
Westinghouse LED TV LD-4655VX Fix - YouTube
? 24:48
https://www.youtube.com/watch?v=N_zPWgEitjE
Aug 7, 2013 - Uploaded by TipsNNTricks
Your Westinghouse TV Parts Here: http://amzn.to/14ETOTN ...LED LCD TV FIX, How To For Samsung Double Image, BlackVertical Lines, Screen ... Samsung TV Won't Turn On - How to Repair Bulging Capacitor for ... Problem with Westinghouse LTV-32W6 - Duration: 5:09. by toddalex4 20,284 views.
Dec 19, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing circuit...it is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
My Westinghouse LTV-32w6 HD has sound but no picture
You may have problem with the T-C0N board, worst case will be the main logic board, try cooling the T-CON board with electronics freeze spray to see if the problem will go away, you can get it from Radio Shack.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 30, 2010 | Televison & Video
After about 2 or 3 hrs my Westinghouse 32'' LTV-32w6 screen starts to turn into line like the picture is all grainy how do i fix this problem?
Does it look like this? http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You may have LCD controller board overheating problem (the pictures show the board with shield removed)
Try cooling it with small fan blowing at the vents.
Mar 28, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sound cuts out in Westinghouse LTV-32w6 HD TV
is it ran through a HDMI cable?
sometimes the source is at fault or it could be a bad hdmi cable or maybe a bad hdmi port. if your using a hdmi try plugging it into another hdmi port and see if that helps
Jan 06, 2018 | Westinghouse Televison & Video
LTV-32w6 won't turn on
were on the power supply is the fuse located
Nov 12, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
