Question about Lisle 29500 High Low Circuit Tester to 28 Volts and Spark Plug Wires
I have a 1986 Honda Civic 1.5 i cant get it to cold start when i do get it started it has a little miss in it, I have almost all new parts new bottom end the only thing thats not new is the carberator which i dont see why that would cause a poor cold start
I got some free "advice" the rate that you all charge cost way more than it was to fix my problem so thanks so very much................
Posted on Feb 28, 2009
Why doesn't this 2000 Honda civic lx turn over when everything else works inside the car?
Honda Civic Coupe Questions - car will not start. battery ok ...
www.cargurus.com > Questions > Honda > Civic Coupe
CarGurusJul 9, 2008 - Get someone to turn it over and see if it is getting spark. ... i have the same issue with my 1993 civic lx it has a 1.5 sohc non-vtec i changed ... comes wen the 2nd click of the main relay it doesn't occurs until after few minutes, few .... My 2000 Honda Civic Ex Vtec will not start, has a new tps, new throttle body, ...
Part 1 -How to Troubleshoot a No Start (1.6L Honda Civic)
troubleshootmyvehicle.com > Honda > 1.6L
Dec 31, 2012 - Difference Between a No Start and a No Crank Condition. ... can cause your 1.6L Honda Civic (Civic del Sol) to Crank but Not Start. ... In other words, the engine doesn't turn over at all. ... 1995, 1996, 1997, 1998, 1999, 2000.
98 Honda civic won't crank (PushStart) - YouTube
? 4:11
https://www.youtube.com/watch?v=X5W7OqjKB8I
Oct 21, 2013 - Uploaded by SkzDaniel
Honda Civic won't start or crank with the clutch but goes on when you push start it. ... 2000 Honda Civic LX with new battery and starter. Still will ...
? 6:34
https://www.youtube.com/watch?v=p7KAO__nM1s
Aug 21, 2013 - Uploaded by Robert SnyperMD
2000 Honda Civic LX with new battery and starter. Still will not start. ... Crank, No Start Diagnosis Honda Coil test. - Duration: 11:17. by ...
Jan 05, 2016 | Honda Cars & Trucks
My 1986 honda civic 1.5 jumped timing. I need to now what parts I might need to fix it and where the timing marks are. I think i need a new tensioner and replace any gaskets that i encounter. please help
best thing to do if it's a overhead cam is get a professional to look at it and make sure it's done right because if you get it wrong and start it, it will cause alot of damage. if it's not just get the #1 piston to top dead center, and make sure the distributor is pointing near the #1 point. the timing mark is on a little plate near the crankshaft pulley. you probably don't need a new tensioner it's probably just the belt is over stretched from age and needs replacing.
Mar 19, 2011 | 1986 Honda Civic
2009 honda civic is struggling to start when its cold
buy a battery that has a higher cold crank amp
Dec 08, 2009 | 2009 Honda Civic
Honda civic esi 1.6 vti i cant satrt
i've found on hondas when the there is a no start problem when the engine spins over fine. when the plugs wear out the cylinders get washed down with gas and it sounds like it has no compression. if this is what its doing put a little bit of oil in each cylinder not too much though then put new plugs iin it, however if there is no spark at the plugs it's probably the distrubutor
Oct 17, 2009 | 1992 Honda Civic
The bike misses when going 55mph
What else have you done or checked besides the plugs. Does it start and idle fine? Test the new plugs. The ark should be bright blue or between 7 to 8 ohms. If the ark is yellow or orange, you may have a bad plug or coil.
Jun 16, 2009 | 1986 Honda VT 500 C Shadow
My 1986 honda civic wagon will crank but won't start.
check your coil it could be shorting out
Jun 03, 2009 | 1986 Honda Civic
What coul be keeping my 1986 honda civic from starting? The plugs all spark, the fuel pump gives gas to the carb, Ive changed all plugs cap and rotor and have tried spraying starter fluid directly into...
It cranks really good sputters a little and makes some loud pops but it will not turn over? FYI:Cranking and turning over are the same thing. When was the last time it ran. The gas could be bad. Did you get new plug wires as well. Try testing the distributor, remove a spark plug, plug it back into the wire, and touch the threads to ground and crank the engine. It should spark. Keep your fingers away, that's high voltage. Remove all spark plugs, spray some starting fluid in each cylinder, then crank the engine with the plugs out. This will clean any debris from the cylinders. Engines need backpressure to run properly, a major exhaust leak hence the popping, could cause it to not run. If you can get it started try to keep it going, full throttle, keep in the starting fluid, it could just need to get warm. I used to have one of them and they don't like it when they're cold.
Mar 23, 2009 | 1986 Honda Civic
Wont start after it died one night
The cap should be marked for number 1. The distributor turns clockwise. The firing order is 1-3-4-2.
Mar 22, 2009 | 1986 Honda Civic
1991 honda civic hb si please help!!
Sounds like it may be a vacuum line problem...double check all the hoses and make sure none are off or broken/missing. Check over the IAC (Idle Air Control) valve too and inspect & clean it out with carb clean or something, could be that the valve's sticking
Oct 07, 2008 | 1991 Honda Civic
86' si starting problem
the fuel pump may be wearing out if its getting hot. i would suggest changing it out
Aug 22, 2008 | 1986 Honda Civic
Lisle 29500 High Low Circuit Tester to 28 Volts and Spark Plug Wires Logo
Top Lisle Measuring Tools & Sensors Experts
Billy Mac
Mai Lor
Prariehog
Prariehog
Are you a Lisle Measuring Tool and Sensor Expert? Answer questions, earn points and help others
