Question about Kenmore Washing Machines
Kenmore 90 Series craked tub
The tub that holds the water has a crack in it and i wonder how hard it is to replace this tub We also have the cracked tub problem with a Kenmore Series 90 washer.
Its model number is 110.26912691.
Please let us know how to get a replacement part and how to replace the cracked tub.
Thank you.
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I have a Kenmore 90 series heavy duty washer that is leaking water all over my floor enough to soak up a couple of towels. What can this be and how do I fix? thank you.
could have a cracked water pump or the pipe that the drain line drains into is backing up.one other thing it could be is bad tub seals,the water will leak from the bottom middle of the tub but most likely it will be the pump,this is an easy fix,pop off the two clamps that hold the pump on and with a pair of plyers remove the two clamps on the hoses,make sure you put down a couple of bath towels to catch water that's still in the hoses,let me know how you make out,next time send model number,one of the most common pumps for your machine is 3363394 but check it with the part number on the old pump and give the parts store the correct model number.good luck
Jul 14, 2010 | Kenmore 22422 Top Load Washer
Crack in the bottom of my Kenmore washing machine tub
What is the model number? Is this a front loader or a top loader? To answer your question, yes, the tub can be replaced. You need to take a look at your warranty information to see if this can be replaced at no cost to you. Most manufacturer's warranties cover the first year against any major defects. However, some warranties are extended on certain parts. Something you may consider.
If you post back with your complete model number, I can give you an idea on how much a replacement tub may cost you, and if you have to pursue this on your own...I can give you the steps required to replace the tub.
NOTE: Marine epoxy or plumbers goop may work as a temporary fix in the mean time.
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not hold water start washing cycle and water runs out the bottom
Likely a damaged hose either from tub to pump or pump to drain hose. Could also be a cracked/broken pump housing or shaft seal. A further possibility would be a rust-through in the outer tub (which can be fixed with epoxy).
Aug 02, 2009 | Kenmore Washing Machines
Kenmore 44024 is leaking water apparently from the tumbler not any of the water sources or drains.
Open the lower kick panel and inspect for the source of the leak. If you feel water or see rusty or soapy residue around the tub bolts that hold the tub halves together, remove the cabinet top and tighten all the bolts around the tub. The bolts should be snug when tightening. If the bolts are ok, feel all around the outside of the tub for holes or cracks.
Mar 04, 2009 | Kenmore 44102 Front Load Washer
Water keeps flowing non-stop with my old Kenmore washer
Check the pressure switch and the pressure switch hose.
Remove the end caps on the console and remove the 2 screws that hold it down. Pull slightly from the bottom of the console and flip it up. On the left side you should see the pressure switch (water level switch) with a few wires and a small hose connected to it. The hose should be connected between the pressure switch and the tub. In most cases the pressure switch hose sometimes falls off over time due to vibration.
Replace the hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (pressure switch side and tub side) and reconnect them making sure to push hose ends securely onto connections. This is done because the hose sometimes stretches at the connection points and you will lose air pressure inside the switch, therefore the water will never shut off.
Alternatively you can use small clamps on each end.
If this doesn't work, check the function of the pressure switch by attaching a small hose to it and blowing lightly into the pressure switch while the machine is filling. You should hear a click and the inlet water valve should turn off. If it doesn't turn off you may need to replace the pressure switch or if the machine fills even when it's in the off position replace the inlet water valve.
Mar 03, 2009 | Kenmore 22422 Top Load Washer
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore 80 series
check for corrosion or cracks on the outer tub.that might be the only problem.good luck.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washer over flows
Dear Cbelton
please inspect the following
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
  • please rate this solution.Thank You..
    Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 80 series leaking
    well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
    Dec 13, 2008 | Kenmore 24832 Top Load Washer
    Washing Machines Logo
    106 people viewed this question
    Sal De
    fordexpert
     Brian Main
    Brian Main
