Question about HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop
HDD problem emminent
I have a Compaq Presario and the I get "HDD failure is emminent", I installed a brand new HDD same exact size and IDE. Loaded WinXP Home everything was great until I loaded SP3 and then received the same message. I uninstalled SP3 and the message went away. I updated the BIOS and reloaded SP3 and the same message returned. This is only day 5 on the brand new HDD and I did run the diagnostic from HDD manufacturer and detected 0 problems on the HDD. I believe the problem is with SMART and XP SP3. How can I get rid of the SMART in the BIOS?
    Brigadier General:
  • 5,158 Answers
You can shut off smart in the bios... i'm not sure which menu... i believe it will be in the second one on the left... that is if the bios will allow you to make the changes
Robert
Posted on Feb 27, 2009
    President:
  • 2,653 Answers
Just enter the bios and poke around. You should see something that says "SMART" turn it off. If there is no option you're probably stuck with the message.
    Sergeant:
  • 319 Answers
The bios menu has an option for SMART enabled. disable it in the main bios menu. hope this helps!
I have a compaq presario CQ80 lap top. I am getting an error that the HDD needs to be replaced. It has a 160 gb hdd, and I would like to replace it with something bigger. I cant seem to find any ac
the only thing you need to know is if it is a sata or ide hard drive (if you look at the end of the drive if it has a lot of little holes it's an ide) then shop for whatever size drive you want i.e 250GB 2.5" hard drive. Because it's for a laptop it will have to be a 2.5" hard drive.
Dec 14, 2012 | Compaq Presario Notebook
I took out my hard drive in my Compaq Presario V2000 laptop...and I'm not sure what type it is..like an IDE, SATA...and whether it needs a 2.5 or a 3.5
Hi
Normally a laptop computer using the hard disk type 2.5 "
Here I attach the hard drive example for your reference.
Pic 1> 2.5" IDE HDD
Pic 2> 2.5" SATA HDD
Tq and regards
Mar 21, 2011 | HP Compaq Presario V2000 Notebook
Disk boot failure insert system disk and press enter
When you encountered this kind of failure this is a HDD error, so check the HDD if it is properly connected. Use another IDE or SATA cable, use also the another SATA or IDE slot of your motherboard. No another way to fix it that is only the hard disk you need to check. Maybe the IDE or SATA cable is bad or the HDD itself. Good luck!
Jan 23, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Hard drive replacement
Hi there, I have an HP nx6110 and it had a WD 60GB 4200 rpm IDE, I bought a Seagate 80GB IDE Hdd and it worked fine. The only think you should be careful is to check if you need a SATA Hdd or IDE Hdd, but I think it's a SATA.
Apr 02, 2009 | Fujitsu Computers & Internet
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
My brand new ASUS ee PC notebook won't boot up. Any suggestions?
check in the bios settings if the hdd is detected..if detected,you need to re-install the windows..if not detecting,you must replace the hdd...ahh! i think the hdd for this laptop is expensive..coz i know its something special..not same like normal hdd in laptop,like ide or sata..its small hdd inside the board...half size for the 2.5" hdd sata or ide
Nov 23, 2008 | ASUS Eee PC 900 16G Notebook
Hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Nov 05, 2008 | HP Compaq Presario 2200 Notebook
HDD Failure
brand new hdd's have to be formated and then partitioned. I have a little tool for yor password problem too .f needed
Jan 07, 2008 | Compaq Presario M2000 Notebook
HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop Logo
194 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
