Question about HP Officejet 4315v All-In-One InkJet Printer
Paper slipping around while printing
It has always worked great until lately. Now when I receive a fax or try to copy, the paper seems to slide so that the printing is sliding around on the page or some of the page doesn't get on the page at all. I have tried different types of paper, but they all seem to be doing it now. It's almost like the rollers aren't gripping the paper correctly. If you can help, thanks.
Dan
  • djr777 Mar 02, 2009
    Thank you very much for your help diddydaveh.
    Dan
  • 154 Answers
Hi, paper has a chalk and dust content, both of which can clog up the paper rollers and cause slippage. use some damp, NOT WET, pan scrubber on the paper rollers and this should stop the slippage.
Posted on Feb 27, 2009
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
Mar 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
When receiving a fax, it seems that several pages of paper always
you mean you're getting 1 or 2 extra sheets when machine is printing faxes? Feed roller and separation pad that pull paper from the tray are worn.....cleaning will help in the short term.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Failed Pick Up
use alcohol and dry cloth and clean all what lubricated,fax machines don`t lubricate!!!!!!!.after cleaning the fax will work properly
Oct 29, 2007 | Panasonic KX-FL501 Plain Paper Laser Fax
Blank copies
Thanks Guest with Best Solultion! OMG! I have had my machine printing blank for over a month now and reading stuff and trying to find a solution. Until finally today I found this page. I read your solution and hit the front like u said for several times and nothing. Finally, after the third try WALA...IT WORKED!!! Thanks again. If anyone has this same problem try this because it really works! Eventhough this is such a strange problem for such an expensive machine.
Oct 04, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
dear sir pleaz select the correct paper size in the user data programing of your machine
Sep 10, 2007 | Canon FAXPHONE L80 Laser
Sending faxes
SEEMS THE RECEIVING FAX IS SET ON AN EXTENSION , SO U WILL HAVE TO FOLLOW THE PROCESS. HAPPY FAXING OMNIPRESENT
Sep 05, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
HP Officejet 4315v All-In-One InkJet Printer Logo
Ben Johnson
