Question about Jensen XS6510DC Car Speaker
What is the size of Jensen XS6510DC car speakers?
I need the size of these speakers ASAP
  • 95 Answers
6.5"
Posted on Feb 28, 2009
Have a Jensen speaker and cover damaged. need to replace. Tell me where
The cover can be mended with good tinkering , use a soft platform and a soft hammer to trim the shape and then if the paint has gone it can be touched .
however is the cover is damaged beyond repair then the only option is the Jensen store unless you re able to source from a scrapped one... check car stereo installation centers.
Sep 14, 2011 | Jensen Car Audio & Video
I have no harness labeling ground, hot or speaker wires, I need diagram
Alot of new stereos have an ISO color code,
This is mine:
Car Radio Constant 12v+ Wire: White/Green
Car Radio Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Apr 25, 2011 | Jensen Car Audio & Video
Jensen CD-510K hooking a 200 watt amp to it.Need to know what wires need to use to hook it up
rca cables for audio and a remote wire. just plug the rca cables into the plugs in the back of the deck and the remote wire (i suggest buying a thicker (speaker wire size) gauge wire since it allows you to get more power out of the amp) to the blue remote wire coming from the deck. you will also need an 8 gauge power wire (12 inches to 12 feet depending on where the battery and amp are) and an 8 gauge ground wire (no longer than 24 inches).
Aug 18, 2010 | Jensen Car Audio & Video
I have a jensen cd6112 radio vol control is not working also will not change bass/tre/ or speakers.Tried reset button but no change .Vol knob won't do anything.
I was installing a speaker and while drilling a spark flew. Didn't think anything of it and finished instalation. When finished the audio didn't work on any of my speakers. I have a jensen cd6112 and the unit seemed to be fine. Tuned in, the lights came on and everything. I hooked a radio straight to the speakers to see if they were blown and they worked fine. Is there a fuse in line with the speaker wires? I would hat to buy another jensen unit and the same problem exist. Any help? Is the jensen unit bad?
Jan 05, 2010 | Jensen Car Audio & Video
Is the Jensen car speaker model cv 650 a 4 OHM spreaker? I'm trying to match a 4 OHM subwoofer.
It should be a 4 ohm speaker as this is the standard impedence for car audio speakers. Jensen does not produce car audio speakers with any other impedences.
Jun 21, 2009 | Car Audio & Video
Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Dec 08, 2008 | Jensen LXA400 Car Audio Amplifier
Owner's manual
go to www.jensen.com and download it is free.
Jun 12, 2008 | Jensen JMC-350 CD Shelf System
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
Apr 13, 2008 | Jensen SCR-60 Stereo Cassette Player with...
No low bass
Check the wiring of the woofers. If one speaker is wired improperly, it can cause the loss of bass and will make the woofers bottom out easily. Check inside the enclosure at the terminals and at the speaker.
Oct 28, 2007 | Jensen LXA300 Car Audio Amplifier
Jensen 9411 WILL NOT LOAD ANY DISC
It's a problem that a lot of people that have this unit is having, the solution is repair center and not to purchase this unit anymore it problem that Jensen audiovox need to use better parts
May 05, 2007 | Jensen VM9411 Car Video Player
Jensen XS6510DC Car Speaker Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
