Question about Kenmore 73422 / 73424 / 73429 Gas Kitchen Range
Oven not working
Hi.  got a kenmore gas range, 73422.  the display is not working, so i can't turn the oven on.  it's got power, the oven light and burners are working.  help!
  • patriciamluc Mar 04, 2009
    um, actually, i just sort of whacked the panel and BEEP! it started working again!  thank you....
  • Kenmore Master
  • 3,361 Answers
Your electronic control panel must be replaced.
Posted on Feb 27, 2009
  • steve
    steve Mar 04, 2009
    I will try that on my next service call.
    Thanks for the report.
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Kenmore 790 oven won't maintain temperature
anyone know where to buy the battery for hand phone model mini i9500 ? manufacturer is
z.doxio
Nov 12, 2013 | Kenmore Kitchen Ranges
My Kenmore Elite Gas Range is reading F1 on the display....the gas burners work on stove but the oven wont work....any ideas??
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
The oven does not work. The self clean does not too
kenmore self cleaning range c970-595084 everything works except the oven will not heat up,on self clean door locks but thats all, top elements work, lights work, digital display works, but no power going to oven elements when i used a tester to check voltage. Can anyone tell me what to do? Is there a fuse for the oven only?
ANY HELP IS APPRECIATED.
TY Fr; Clyde
Mar 15, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore GAS Range, model 970-334422, display/oven control went blank, light still works in oven.
it is very likely that the display may have gone bad. but before you buy a new one does it have any thing on it at all
Aug 19, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
My oven
If you don't mind me asking mschampaen, what's exactly happening. Do you have any small little lights on in the front of the oven around the control knobs? Or, a digital display readout somewhere on the oven? A light that goes on when you open the door? Something that indicates there's power getting to the oven. If not, check your circuit breaker in your house electrical panel. It should be a 2 pole, 50 amp. cir. brkr. To reset, turn the brkr. to the off position - then turn it back on. Then go back to your oven and open the door to see if the light comes on. I'm trying to rule out a power problem to your oven first. If this doesn't work, feel free to contact me again. Hopefully, this will do it. Good Luck to you! And let me know if this works for you, otherwise, we'll go to Plan B...:) - Jim
Mar 29, 2010 | Kenmore 73422 / 73424 / 73429 Gas Kitchen...
Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Mar 28, 2010 | Kenmore 73422 / 73424 / 73429 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
New Electronic Oven Control does not work, Kenmore model 7909634
our top elementes work but the oven and the display don't . All fuses are good and nothing looks burnt. Some smoke came from inside the oven but the elements look good.What's wrong?
Jan 21, 2009 | Kenmore 36665 / 36669 Gas Kitchen Range
Kenmore 73422 / 73424 / 73429 Gas Kitchen Range Logo
174 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
