Question about Sears 24 in. 14181 Built-in Dishwasher
How can I shut off the water supply to the dishwasher? It fills slowly with water from the top (while not running), and then water spills out over the kitchen floor. By pressing the 'Drain' button, the water will drain out, but I have to get to it before it floods. It takes about 4 hours for it to get to the overflow stage. It is a Jennair model, about 9 years old. We have a lot of limescale, it is probably time to replace it, but for the moment my main concern is to stop the leak. Thank you for any advice.
  • 188 Answers
Most water supply lines are attached to the hot water supply under the kitchen sink. If not it may be accessible from the basement somewhere under where the dishwasher is located.
Regarding the issue with the dishwasher, the inlet water valve is no longer closing because of the limescale that has built up inside. That is why it fills on it's own even when it's off. Instead of replacing the dishwasher you could just replace the inlet water valve if you want to get a few more years out of it.
Posted on Feb 27, 2009
Kenmore dishwasher filling with water when not in use
The water inlet valve is defective.Turn off the power and close the valve to the water supply line Remove the kick panel on the front of the dishwasher remove the supply line, the clamp to the supply hose, the electrical connectors, ans the screws holding the valve. Reverse process to reinstall. Turn water on and check for leaks Turn on power and you are good to go
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Water pours into dishwashe and spills out when not running
sounds like you have a bad water valve solenoid, however their is a float switch on inside btm floor frt of dish washer that senses the level and cuts off the valve, however if the valve is bad then it will never shut off. good thing you were home. i would replace the water valve, that is located behind the front access panel . hope this helps
Sep 17, 2009 | Danby 22 in. DDW399 Free-standing...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The clean water fill will not shut off and water overflows from the dishwasher onto the floor. We had to turn off the water supply to the dishwasher to get it to stop.
Fill valve is shot , new one required
Ps
Does it still run when you remove the power if so the above applies
If it shuts off then the problem sits with the pressure switch
Jul 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher slowly fills up with water after wash cycle completed
Inside the bottom of the dishwasher under the lower rack to the side there is a float that regulates water level. jiggle it up and down a few times , it will be OK. Vitally
May 12, 2009 | Dishwashers
Dishwasher top spray bar does not spray due to low water fill
Check the water hose going from the sink to the dishwasher to make sure it is'nt clogged, if there's a water shut off valve under the sink make sure it's fully open, also check to make sure the spray arms at the bottom of the dishwasher that supply water to the top rack is clean with no debris or obstructions in the spray hole's, the water entering the dishwasher should be at a warm temp, if it's cold the dishes will not get clean, you should have good water pressure from the house supply for it to fill properly, the float is also called a flood switch, it should not be activated during the water fill cycle, if it's activated it will shut off the water inlet valve and the wash cycle will stop or the dishwasher will drain, if your still having wash problems it could be a defective water inlet valve or a bad timer, if that's the case you might have to call an appliance repair man, hope this helps, good luck.
Mar 28, 2009 | Dishwashers
Water coming into dishwasher when not running
Removed intake water valve assembly and found a piece of plastic wedged in intake port preventing valve from closing. Piece of plastic was old filler tube from old hot water tank which disintegrated and got into hot water pipes in home. Similar pieces of plastic have affected water mixer valves at various sinks in home and have also plugged aeration screens.
Jan 13, 2009 | Dishwashers
Removing dishwasher
Washers have a fill line to a small blue valve underneath, there is also a power supply, and drain line hose. Make sure to turn breaker and water supply off, before removal
Jul 06, 2008 | GE Dishwashers
Frigidaire Dishwasher Problem
by the sounds of it.i think the water inlet valve that lets water into the machine has gone faulty leaving water slowly seep into the machine, you could either replace this valve..or a cheaper solution if you can access the rear of the machine most water supplies would have a small value installed on the incomming supply,you could simply turn off the water till the next time u need to use it.
Jun 28, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Sears 24 in. 14181 Built-in Dishwasher Logo
169 people viewed this question
Top Sears Dishwashers Experts
Are you a Sears Dishwasher Expert? Answer questions, earn points and help others
