Question about Xerox Phaser 8400 Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only yellow is evident. I have cyan and magenta color cubes in place. On the cleaning page - yellow and black are the only 2 colors that seem to be evident - a slight stripe of faded maroon/red and even less of a faint green which my guess is the cyan. On the light stripe test black is evident but some missing stripes - some faded and some distorted. The yellow is the best of the 4 colors with very few missing some a faded black and very few distorted. The Magenta the lines are mostly missing some distorted and some a faded mix of black. The Cyan almost all missing with a few distorted blackish lines with some lines that are really more like a faded light green. When I check the waste bin there is excess wax equally for each color. Any ideas?
    President:
  • 2,072 Answers
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Posted on Feb 28, 2009
Faded black
Hi Evan Z,
Not quite sure what you mean faded black.
Is the print faded at one side or overall the page?
Now think if it's faded on on seed then it's possible that it could be a build up of toner on the laser head unit. If it's an overall faded page then look for possible poor connections on CRU's.
Check the other working CRU's do they look the same? Don't start turning rollers the opposite way they would normally rotate.
Finally a light overall image can occur when the developer tank has seized up, or a broken drive gear, effectively starving the developing system of fresh replenished toner.
All developer tanks regardless of colour work in the same way, perhaps a slightly different shape as to avoid incorrect fitment.
if in doubt goto the www.xerox.com website and seek more help there.
Good luck.
Sep 01, 2013 | Xerox Phaser 6130 Laser Printer
Xerox Phaser 8400 prints pdfs in half page
I've seen this issue on some of my other Xerox machines (not the 8400 specifically). 9 times out of 10 the solution is to update both the printer driver to the newest version, as well as updating Adobe Reader to the newest version.
Here are the links to each:
Xerox Phaser Drivers
Adobe Reader
May 04, 2011 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 8400 problem
I would call xerox second level support. There has to be a problem with that driver . I have seen this problem more than a few times. call 1-800-835-6100 and see if they have an alternative. This is an obvious flaw in the driver.
Mar 08, 2010 | Xerox Phaser 8400 Laser Printer
Phaser 8400 only prints first page of multuple page print job. help!!!!
I would reload the driver, or switch drivers. Best on an 8400 to be using the most current PS driver. You can find it on the Xerox.com site.
Just click Drivers and downloads, then in the search box type in 8400.
Then click drivers and downloads once again and download the newest driver.
I hate to ask you to do this, but that also sounds like machine software ( firmware) corruption and shutting it off and on could cure your problem also, But yes I know, that wastes ink.
Jan 06, 2010 | Xerox Phaser 8400 Laser Printer
My xerox phaser 6250 prints the first page fine then the black fades on the following pages
Your toner supply route is partially plugged and it can't keep up with the demand. It's not an easy process to clean it but a can of air, toner vac, and an area you don't mind getting dirty are necessary. Pull the imaging unit out and dig around, blowing and vacuuming out toner. Also, pull the black toner cartridge and work through that way as well. If your black toner is low, that might be the problem.
Jul 13, 2009 | Xerox Phaser 6250DP Laser Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Xerox 8400 light printing
No, If one lamp goes out they both will not function. They do not have anything to do with print quality.
You may have a bad maintenance kit. but more than likely you have a bad print head.
Run the cleaning , eliminate stripes and eliminate smears modes. But more than likely the print head is bad. I would say a bad print head is about a 95 percent chance of causing your problem.
The halogen lamps only heat the drum, and if one was bad the machine would fault out with a 15,004 code.
Oct 11, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Xerox Phaser 6250 started printing bad
That really sounds like the imaging unit cleaner has an issue.
If you have one try the imaging unit, I really suspect that is your problem.
Black is Faded or Missing Step 1 Clean the Laser Windows and Remove Excess Toner From the Imaging Unit Step 2 Check or Replace the Imaging Unit Gear Retaining Pin Step 3 Replace the Imaging Unit (installation instructions) ic-film.gif
See if this link works. Xerox is infameous for these not working.
Apr 08, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 8400 Laser Printer Logo
1,388 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
