Question about Edison 40 Pint Dehumidifier
Water does not come into bucket. Light will not come on unless holding piece in back of humidifier. Humidifier is by Martin Industries, Edison 40, Serieal No. 93010617, Model # DHF or DUF letters no clear and then the number 40. It is about 30 years old. Is there a place in the Chicago area where dehumidifiers can be fixed. A piece in the back is bent, when I whole it up the light comes on and then it works.
    Problem Solver:
  • 16 Answers
It sounds as if the bucket full switch is broken or out of adjustment
Posted on Mar 30, 2010
Humidifier is draining on floor while bucket is not yet full- why?
ck that float level in corner of bucket is free and moves well , also verify that unit is level as this affects the float and amount that bucket can hold , also a ck that drain hole that allows water to enter into bucket is not partways plugged with something , should be pencil size hole there
Oct 01, 2014 | Danby Dehumidifiers
Water does not fill in the Aprilaire humidifier on my furnance
It sounds like the feed has been shut off or pluged. Be sure the feed is off, remove the feed from the humidifier. open the fill valve slowly and run water into a bucket or whatever. If it does not run you found the problem, if it does then it is probably the fill solenoid valve on the humidifier.
Mar 21, 2014 | Edison 40 Pint Dehumidifier
GE Humidifier smells terrible
Probably mold in the collection device that empties into the bucket. Try applying Lysol or similar mold killing spray. This is a big problem with automobile air conditioners too.
Sep 13, 2012 | General Electric 65-Pint Dehumidifier...
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Water is no longer collecting in bucket, but appears to leak out of humidifier. Humidifier also ices up.
Basically there is a drainage blockage from the humidifier to the bucket. Take one for the boys and **** hard on the pipe which very possibly will release the blockage.
May 23, 2010 | Kenmore 54351 Dehumidifier
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Feb 16, 2010 | Kenmore 54501 Dehumidifier
Humidifier runs continously, even when humidity has seriously been reduced,very little water appears in catch pan at end
You have adjusted the setting to 50% or higher and this still goes on? Id move it higher and higher until it goes off.
Try that and let me know.
Sep 27, 2009 | Edison 40 Pint Dehumidifier
Dehumidifier not sure is working
There is water in the bucket or no water in the bucket? If there is water in the bucket then empty it and put it back. If there is no water in the bucket then make sure the bucket is all the way in, (there is a switch that senses the bucket). If the bucket is not all the way in the de-humidifier will not work. If you do not hear it, it is not working.
Jun 21, 2009 | Dehumidifiers
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
Edison 40 Pint Dehumidifier Logo
167 people viewed this question
Top Edison Dehumidifiers Experts
Gil Shultz
Daryl Gleaton
Are you an Edison Dehumidifier Expert? Answer questions, earn points and help others
