Question about Kicker (ZX350.4) Car Audio Amplifier
I have a kicker zx350.4 that is pushing two 6.5 pioneers and two 6x9 kenwoods. I have had this setup for over a year. The other day my highs started fading in and out. I figured it was my xmradio but the bass stayed strong, and when I turned the volume down the highs came on. I turn the radio off and the car for about three hours. When I started the car again the speakers were oding the same thing. I messed with the fade on the Panisonic head unit and I found that only one speaker was working.(driver side back) The next day I had the volume low and all the speakers came on but when I turned the vol. up they cut out and went back to just the one.I have checked the wiring and it all seems good form front to back. I am not sure what to do and I don't have the cash to buy a new one. HELP ME
  • ramox Mar 02, 2009
    I dissconnected all the wires to the speakers except the one that is working. I did the test on each channel and the speaker worked on all of them. I then used an old speaker and did the same test with the same results. I took out the 6x9 that wasn't working and could see a wire going to the tweeter was broke and the speaker is blown. I then took out the front passenger speaker and its blown but when I straight lined it to the amp it played. I belive it is a wiring issue. I re set the gain for the one speaker and it worked at maximum volume. I went home and the spaker started cutting out. After it cut out it wasn't as lound as before. It has cut out and got softer over the weekend. Now I turn it to 37 which is almost max(40 max) and the seaker sounds like it on 15 but the bass sounds perfect. Can it be the wiring? Could it be may HU's amp? Or my kicker amp itself? I will use a voltage tester on the amp like you said.
  • Perry Babin May 11, 2010
    Move all of the switches and controls on the amp to see if any affect the sound (going on/off).
    You may also have another problem that's causing the amp to go into protect.
    If you have another speaker (that you know is in good working order) that you can use for testing, disconnect all speaker wires from the amp and connect the test speaker to one channel at a time to see if the problem remains. If there are never any problems when driving the test speaker alone (no matter which channel it's connected to), suspect the wiring.
    You should also check the voltage at the B+, remote and ground terminals on the amp to confirm that the voltage is at or above ~11.5v.
4 Suggested Answers
  • 631 Answers
SOURCE: Prot. light at High vol. (forget Bass CD)
You may have the speakers wired for the wrong impedance.
How many ohms per voice coil?
How many voice coils per speaker?
If the speakers are DVC, are the coils of each speaker wired in series or parallel?
Are the speakers bridged on the amp or one per channel?
Posted on Jul 07, 2008
  • 11 Answers
SOURCE: ZX700.5 cutting out at 60% volume
im pretty suree you don't have enough watts to keep the speakers going and that's why it cuts off on you when you turn it up =(
Posted on May 13, 2009
  • 30 Answers
SOURCE: speakers cut off when bass goes up
probably the amp going to safe or protect mode judging by the fact that you have 3 subs wired to it i would say it is not 1 ohm stable try disconnecting 1 sub and see if it still happens this will be running a 2 ohm load rather than 1 if it stops happening then you need to figure out a better wiring configuration that will work with your amp.
Posted on Jul 03, 2009
Speakers cutting in and out at high volume
The amp is going into protect on the two channels powering the speakers. Turn down the gain on those two channels. You also may want to consider crossing over the speakers a little higher than they are now.
The rating on those speakers are way too high. 6.5's and 6x9's will take 50-100 clean watts tops before they start to break up.
The best solution to get it perfect is....unplug the subs. Turn the gain on the speaker channels all the way down. Then turn up the deck 80% as high as it will go. Play a song. Then increase the gain on the amp until the speakers are as load as they go without distortion. Shut off the car, replugg in the subs and do the same thing. Gain on sub channels all the way down, deck then to 80%, find a bass heavy song, then turn gain up until subs become distorted. If you do this procedure your speakers and subs will be "gain matched" to the proper levels.
Good Luck
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
I have a kicker ix 500.4 hookd up to polk audio 6x9 and 6.5. if you play the system past about 25 volume the subs will keep playing but the speakers will cut out for a few seconds as if its hiting the
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
How to connect 6x9 pioneer speakers
Do you mean the Factory Speaker (Conecters) If you do they will have to be changed, To the same type of connecter that is on the speaker wires that come with the 6x9"s
Dec 05, 2012 | Pioneer Ts-a6974r Car Audio 6"x9 6x9 3-way...
What kind of amp do i need for 2 kicker ds6930 140 watts peak and 2 ks6930 6x9 watts peak 150 and 3 Kicker KS350 3-1/2 40 watts each peak
600 Watt to 1000 Watt 4 CHANNEL AMP for the four 6X9's and a less powerfull 4 Channel amp thats at least 200Watts to 400Watts peak for the 3 3-1/2 kicker speakers. Because if you try to connect the 3 3-1/2 speakers to only 1 4 channel amp that the 6X9 speakers are on you risk of overheating the amp and blowing the speakers too!!!
Apr 05, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
How to get a display ''protect off of my car audio?
one of your speaker wires to the internal amp is shorted. turn power off and make sure they are not touching metal or each other and then hit reset again. if this doesn't help your power ic may be fried inside the stereo or a speaker is shorted.
Nov 29, 2008 | Kenwood KDC-MP435U CD Player
Power from the kenwood 9103D to the Kicker comp 15's is on n off
Most times I hear of people turning up the volume on a head unit and cutting off on the amp it tends to be wired to a speaker with the wrong impedance. I googled kicker comp and got tons of different models, not to mention almost all of them were 250 watt rms. That amp is 900 watt RMS at 2 ohms. If you only have 1 woofer, you can't possibly wire it wrong being all the subs I've seen in the results were 4 ohm. If you are using just one though, you should get a larger speaker, both 2 ohms and 1000 watt rms to prevent distortion. I'm afraid I can't answer your post without further information on the sub you are using.
Nov 20, 2008 | Kenwood KAC-9103D Car Audio Amplifier
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
Car Audio & Video Logo
343 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
