Question about Xerox WorkCentre M-24 Color Copier
We have 2 minor problems we are trying to solve
#1 We would like to reduce the paper waste in our office. How do we stop the page that comes before the work I believe its called a banner sheet.
#2 Our printed work comes uot in the middle of the machine. It used to come out on the top. What did we do...how do we undo it LOL.
thank you!
    President:
  • 2,072 Answers
I am going to have to send your answer in multiple parts since the procedures are lengthy, You have to turn the banner sheet off on BOTH the machine and driver. The procedures you need will follow. In several parts. Sounds top secret doesnt it LOL....
How to disable it on the machine.
  1. Press the [Access] button (key symbol) on the Control Panel. The System Administrator - Password Entry screen will be displayed on the Touch Screen.
  2. Enter the administrator password using the numeric keypad on the Control Panel, and then select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
    NOTE: The default password is 11111. Your password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button and re-enter the password. If you want to cancel the operation, select [Cancel]. If the administrator encounters a problem with changing the access code, or forgets the code, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Print Mode Settings].
  6. Select [Others].
  7. Select the [Banner Sheet] (option 3).
  8. Select [Change Settings]. A list of options will be displayed.
  9. Select [Off] to disable the Banner Sheet.
  10. Select [Save].
  11. Select [Close] three times.
  12. Select [Exit] to exit.
Posted on Feb 28, 2009
  • Rick Kasper Feb 28, 2009
    Disabling the banner sheet on the driver requires you to go to your computer and click on control panel then printers.
    Sadly I cant tell you exactly where to go, because the PS , PCL5 and PCL6, and Netware, and web drivers are set up differently. BUT that being said, right click on the printer once you see it on the screen, and click on properties. Then search for banner page and disable it.
    NOW, Please so you don't make yourself insane and start needing tranquilizers, if the machine is on a network with several computers. Disable the banner sheet on EVERY computer connected. The M24 is famous for enabling the banner sheet on the machine if anyone prints one. Its a software issue, and most versions enable the banner sheet if any computer selects it.
    The answer to your second question. You will select print not copy mode.
    The other thing you can do is this. At your computer , select your browser, IE, firefox etc, and in your address box type in the printer IP address, the Xerox centerware software will display all the printer and its properties on the screen, you can set if from there.
    That is a nice feature , hope this helped.
      Touch Screen.
      NOTE:
    5. Select [Copy Mode Setting]. The Copy Mode Setting screen will be displayed.
    6. Select [Copy Defaults].
    7. Select [Output Destination].
    8. Select [Change Setting].
    9. Using the numeric keypad, enter one of the following settings:
      • 0 = Center Output Tray or
      • 2 = Finisher Tray
      NOTE: The default is 0; Center Output Tray. The optional Finisher must be installed to use the Finisher Tray.
    10. Select [Save].
    12. Select [Exit].
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
Having reduced 3 inches missing copy print of Legal page (8.5 x 13)
Hi..
me too having same problem in MS Office..but finally i observed sometimes paper sizes or faulty..so try to reduce the paper size..
Apr 05, 2014 | Konica Minolta Bizhub 500...
Creased paper
If that happened to me I'd try printing a dozen - 100, if needed - pure blank white pages in an effort to clear any other problem without wasting toner.
Nov 05, 2017 | Samsung Office Equipment & Supplies
I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
May 20, 2010 | HP Photosmart C5280 Printer
Dell photo 864
You might need to speak to Dell or a specialist repair shop.
Until then, please, if wasting paper is the 'only' problem why not just start if up with a piece of waste paper in the feed?
Come to that, why not leave it switched on? Of course that will waste a bit of power but that's not likely to cost more than the power or the ink it wastes on testing itself every time it's switched on...
Nov 29, 2017 | Dell Photo 964 All-In-One InkJet Printer
Incoming faxes always go over to a 2nd page - just a small amount - but it waste that next sheet - how can I make it fit better - or shrink the page 5% to fit better? Dean
Printing a Reduced Incoming Document
Your machine can reduce the size of an incoming fax to fit the size of the paper
in your machine. Select ON to turn on this feature.
After you connect Cassette #2, you can turn on Automatic Reduction for each
cassette. (See Turning on Cassette #2 (Option for FAX-4100 and FAX-4750e), Page
4-1)
1 Press Menu, 2, 1, 5.
2 If you have the optional Cassette #2,
press or to select CASSETTE #1
or CASSETTE #2, and then press Set.
3 Use or to select ON (or OFF), and
then press Set.
4 Press Stop/Exit.
If you send faxes from a computer on the same phone line and your Brother
machine intercepts them, set Easy Receive to OFF.
Cassette #2 can be purchased.
Aug 24, 2009 | Office Equipment & Supplies
Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Feb 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Valid page names message driving me nuts
when printing specific pages the valid range is in this format 1,3,5,7,9,11 etc or if printing even numbers 2,4,6,8 etc or if printing specific pages 1,5,17,21,23,24,32 etc
what makes it a valid range is the comma between the numbers, no spacing and no full stop at the end
to further add confusion
when printing all of the pages just click all pages and it will print one sided all of the pages so no numbering is required
however if you want to save paper and reduce the size of the document
click pages 1,3,5,7,9,11,13 through to ,57
print those pages then turn them all around and upside down reinsert in the printer
now select pages 2,4,6,8 through to ,58 and print
that will give you printed data on each side of the paper in the correct page number order
to get to know how to reinsert the paper test with a print page 1 then reinsert and print page 2 to make sure that you have turned the paper the right way round
Jun 28, 2017 | Samsung ML-2510 Laser Printer
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Jun 17, 2008 | Samsung CLP 300 Laser Printer
Two pages
In the fax mode, Press the options button till you Blank paper size & change it to Letter. it should solve the problem
Jun 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Xerox WorkCentre M-24 Color Copier Logo
471 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
