Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Good battery & good starter but won't crank craftsman lt1000
  • joe May 11, 2010
    will not crank or will not fire? have you checked the fuse near the positive cable?
Check and see if the white wire on the starter solenoid has voltage when the key is in the start position. If so, the solenoid is bad. If not, back probe wire until you find voltage.
Posted on Feb 28, 2009
Lt1000..started backfiring, clanging..then quits..
Check the flywheel key, sounds like it may be out of time. If the flywheel key is in place, you may have something internal on the engine.
Jun 03, 2016 | Craftsman Garden
Craftsman lt1000 manual
check starter solenoid
Jun 12, 2013 | Garden
Riding mower won't crank with a good battery
could be a safety switch use a jumper at the solenoid then work your way back to the switch it'self
Mar 24, 2012 | Craftsman Garden
Electric starter will not engage engine on a craftsman LT1000. The starter is turning but just hums . Is there a gear on top of the starter that could be loose. Also can I use a rope to start this model
did you have the battery disconnected? beleve it or not it is possible to connect the battery the wrong way and the starter will just spin the wrong direction. this will cause the starter gear to not engauge with the fly wheel. also on a lawn tractor the battery wont blow up if connected the wrong way.
Feb 09, 2010 | Craftsman Garden
Craftsman LT1000 Wont crank over.
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
Nov 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
No power at all.
Check electrical continuity from battery to starter
Jun 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
715 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
