Question about Roper RAS8445KQ Top Load Washer
ROPER RAS7133KQO My washing machine will not spin.It does do everything else.It is not making any noise and works great other wise.I was told this modle does not have a belt.Is this true?
  • Roper Master
  • 8,220 Answers
Their is no belt. This washer uses a reversing motor. The motor has a double shaft. One side holds the pump. The other side connects to a drive couping to work the tranny.ROPER RAS7133KQO My washing machine will not - 117be3b.jpg
The coupling will break because of normal wear,quilts or rugs,low water heavy loads etc. The pump and motor are held by convenient spring clips. The motor has a quick connect so no issue with wiring.To access the innards you have to remove the skin on this beast. Depending on the model you basically swing up the controls. Pop the clips holding the skin on and tip the cabinet forward to remove it. Then you can easily access all the vital parts of the washer. You can even jump out the lid switch and run the washer with the case off(when looking for various leaks). They say a picture tells a thousand words so I have a compilation.
Click HERE
Here is some more fabulous sites you can copy and paste to:
http://repair2000.com/coupling.html
http://appliancejunk.com/motorcoupler.pdf
Posted on Mar 07, 2009
    New Friend:
My machine will not drain or spin, I took off pump and do not see anything clogging it up and the coupling is not cracked or broke, what now.
Posted on Jul 27, 2013
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Please help me ! My Roper by Whirlpool washing machine can't stop spinning on it's own. :(
Does the tub move sideways. Try pushing the top of tub side to side at the top. There Is A Wedge That Clamps Tub To Spin Tube. Also try to turn tub with washer off, the brakes could be bad not grabbing. Sears parts direct has a good diagrams.
Mar 29, 2017 | Washing Machines
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Roper wash machine ras7133kq1
no theres something in your pump,,it up against the impeller in your pump.....onthejob
Jan 31, 2009 | Roper RAS6233KQ Top Load Washer
Making loud noise and not spinning RAS7133KQO
its direct drive. you need to pull the pump and motor and replace the motor coupling. easy fix dont junk it.
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Roper washing machine roper rax7245kqo
more than likely something is jamming your pump now your coming up on the post with another user as having the same problem but its not the same kind of machine im getting ready to answer the first user who has a front loader and it may pop up to you so disregard that. Reply to this message and ill tell you how to check yours
Jan 01, 2008 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
397 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
