Question about E-Machines T6532 PC Desktop
I have to leave my computer turned on all the time. If I do turn the tower off, it takes anywhere from 2 to many more trys pushing the on/off button for the computer to ever boot up??????
  • 59 Answers
Sounds like the power supply to me. I have had the same problem before. Hope this helps.
Thanks for using FixYa.
Posted on Feb 27, 2009
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
Computer wont turn on
Make sure the tower is getting power. There will be a green light on the back of the tower where the power cord goes. Make sure the cord is snug and that it is securely plugged in to your power source - I'm hoping it is a power surge strip and in which case, make sure the surge strip didn't get unplugged or turned off. If you have it plugged directly in to the wall then make sure that outlet has power by plugging something else in to it that you know works. After doing all of this, make check to see if there is a light on the back of your pc. If not, unplug the power from the back of the tower, wait 30 seconds at least, and then plug it back in. Hit the power button on the front just once, if it doesn't power up, press and hold the button in for a 2 seconds and release. If that doesn't work, your power supply may have gone bad. That happens from time to time. Good luck, hope this helps!
Jan 20, 2013 | Thermaltake Computers & Internet
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Dec 23, 2010 | Dell Dimension E510 PC Desktop
I have an hp desktp that was working fine but now when i push the button to turn it on the button stays yellow and nothing boots
sounds to me like the power suplly unit as this would be the first thing i would change in the shop if this answer helps please rate it
May 13, 2010 | Computers & Internet
HP a1050y no power I tried all suggestions posted, and everything
Try Unpluging the power supply and press and hold the power button for about ten secs - leave it off for about two min and plug it back in and turn the computer on.
see if that work,
Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
HP a1050y....Push the button to turn it on, and
You might have a bad power supply, or something might have loosened inside the case. sometimes if the memory or processor get jarred , they might need to be reseated. unplug all the cables from the back of the tower, only leave the power cord in then try to power up. Sounds like it might be power supply or Maybee the motherboard. Have a computer tech check all the inside connections. Good luck..
My hp w1907 monitor has suddenly stopped working!!as soon as i turn on the tower it just displays"monitor is going to sleep"PLEASE HELP!!!
I love this one. I've actually done this many times before and have been successful.
1. Turn the computer off and unplug the power cord from the back of the tower.
2. Press and hold the power button for about 3 seconds while the computer is unplugged (this drains the remaining power from the capacitors on the motherboard).
3. Plug the computer back in and turn it on.
If that does not work, follow steps 1 and 2 again, but this time:
3. Open the computer while it is unplugged and unplug the power supply from the motherboard then hold down the power button again for 3 seconds. (You may also want to take the RAM out and put in back in)
4. Plug everything back in and turn the computer on.
Mar 13, 2010 | HP w1907 LCD Monitor
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
E-Machines T6532 PC Desktop Logo
69 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
