Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Changing my laptop wireless default position
When I first got my laptop, as soon as I switched it on it would search for wireless connection. My computer went in for repair and vista was reinstalled. Now when I start up my computer I always have to manually go to wireless settings and switch it on. Is there a way I can change my computer default to switch wireless on?
  • tony_rogue Mar 07, 2009
    Thanks for your advice. I carried out your instructions but doesn't seem to have made a difference, I still have to manually switch on wireless at start-up.
    Is there anything else I could try?
    Scholar:
  • 82 Answers
Go to Start > Control Panel > System and Maintenance > Administartive Tools. Double click on Services. Scroll to the bottom and you will see WLAN AutoConfig. Double click on it.
It is most likely set to manual. Click start if it isnt started already and change the startup type to Automatic.
Click OK , reboot and see if it works now.
Posted on Mar 04, 2009
How to switch on wireless
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps.
Dec 10, 2012 | Computers & Internet
Change wifi password
If the default password on the D-Link has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05) Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (WPA or WPA2 encryption) Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Nov 19, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
How i do keep my wireless switched on
hope this helps
Sep 26, 2012 | Computers & Internet
My toshiba satellite pro L300 is unable to connect wirelessly to netgear N150 Wireless ADSL2+ Modem ROuter ~ It keeps looking for
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 21, 2012 | Toshiba Satellite Pro L300...
How do i go about retrieving my ssdi password without going thru another setup
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
You can now configure the wireless settings or look at the SSID and encryption settings.. You need to configure the wireless card in your computer/laptop withthe router's wireless settings so it can connect to the D-Link wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 03, 2011 | D-Link Wireless N 150 Home Router 4Port...
I have new laptop dell computer and want to use it at home with my d-link wireless adsl router but am unable to connect to internet and it asks me for security key number
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
Jul 11, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Having trouble going wireless as soon as i unplug i lose the web
Hi There,
With the limited information I don't think a complete diagnosis and resolution would be possible as there are so many factors involved however I will give you some advice to try.
Because the wireless and cabled connections operate as completely independent entities you shouldn't expect a continuation of service from one to the other, in fact operating in this way causes greater issues than not connecting by cable at all
assuming once connected by cable you have a good internet connection the the problem lies completely with your wireless connectivity between you router and your laptop.
what you should do to diagnose the fail point
1. connect by your cable as you have been doing press start press run type CMD into the box pres [enter] to bring you a DOS screen (black white writing)
in this screen type IPCONFIG press [enter]
the writing that passes by are your IP settings one will be called Ethernet and under which it will have an IP address for your router called DEFAULT GATEWAY make a note of this number. it will probably (though not exclusively) something like 192.168.x.x depends on the make of the router
type IPCONFIG /RELEASE disconnect your cable and reboot your laptop
if your laptop has a switch or button to turn on wireless turn it on once widows has loaded
in your systray (the row on little icons near your clock) you should have something that represents your wireless connectivity, either a strength meter or a computer screen with a plug at the top left corner, click on this and you should see the list of wireless networks available in your area in theory the one closest the top and strongest signal should be your router
if you do not have this then the drivers which make windows recognize your wireless adapter is missing, connect again via wired, search out your laptop, download and install drivers.
if its there click on it and click connect. you should then be prompted for your password (either set by you or written on the bottom of the router "SSID", "WEP" or "WPK" the prompt will tell you which one (of the security measures) and the router will have the password written next to this title.
wait a minute and it should connect and work
if you do not know this and have not set it
connect again using cable after a reboot
launch internet explorer
in the URL bar where it currently says" www.fixya.com/blah blah" type in HTTP://and the number with dots you wrote down earlier so http://192.168.2.1 or whatever it is (probably ending in .1)
this will take you to your routers config screen again it may require a DIFFERENT password if you do not know this check your routers manual, or Google search default passwords for your model of router.
select wireless, select security options, select WPA protection and give it a password that you can easily remember, any device you wish to connect in the future will prompt you for this.
find your rooters save option and also reboot the router, when its back up and running reboot your laptop and repeat the process from switching on your laptop above.
anyway.
hope this helps, took me a while to write it so if it did please give me a good review on www.2pages.freeindex.co.uk
Mar 24, 2011 | Toshiba Computers & Internet
Cant connect to wireless internet. Diagnosis tells me i am not plugged in. The wireless reception is excellent. When i connect my laptop direct to my wireless hub it works but without connection to hub no....
logon your ROUTER BY ENTERING IP IN BROWSER WITH ADMIN CREDENTIALS
OR IF YOU FORGOT PASSWORD THEN RESET IT BY RESET SWITCH TO FACTORY DEFAULTS
WHICH IS ON BACK SIDE OF ROUTER THEN CHANGE SETTING --SSID --WEP KEY
PUT A NEW KEY AND RECONNECT YOUR LAPTOP
Feb 05, 2011 | Dell Latitude D600 Laptop Computer -...
Want Instant wi fi when turning on my laptop
Hp comes with a wi-fi utility and I dont find it very useful, so first, you might want to uninstall the software from add or remove programs and then use windows to manage your wi-fi.
Once you connect to a wireless network from 'network connections', it will automatically be set to default and should connect at the computer startup.
If it does not connect automatically.go to 'change order of prefered networks' and put your prefered network on top and set to automatically.
Dec 29, 2008 | Computers & Internet
Compaq laptop won't connect to internet
on my hp the light is blue when switch is on. go to network and conn. and make sure ur wireless is turn off there. cause if my switch is in the on position and i turn it off hp wireless assistant the light will glow orange eventhough the switch is on . ? Just had an issue simular to this one, hope it helps.
May 19, 2008 | Computers & Internet
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
244 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
