Question about Garmin GPSMAP 60CSx GPS Receiver
Buzzing noise when i turn off Garmin 60CSx
Whenever i turn off my Garmin 60CSx it makes this buzzing sound and it wont turn back on or stop buzzing until i take out the batteries and put them back in. I really need help with this fast, i have tried redownloading the new firmware with no luck.
  • upclosecw Mar 21, 2009
    Same exact problem - just picked this thing up yesterday ---used "5 times"--- was new in June. What's weird is that it didn't do it every time until I put new firmware in it a couple hours ago...it did do it at random before that.
    I'm going to try to get the reciept from the guy and hope to send in for a new one at best....anyone else see this problem?
This problem is Mac OSX related and can be solved using Cleaneject http://www.javawa.nl/cleaneject_en.html
The OSX operating system creates several invisible files and folders on USB-disks, camera's and GPS devices and the Garmin GPS devices can't cope with these invisible files and folders.
Cleaneject erases the invisible files and folders.
Posted on Jan 30, 2010
  • oboeplaying
    oboeplaying Sep 17, 2012
    I used this program and now my SD card doesn't work in my GPS....it crashes!
My unit would make a non stop beep... not sure if same as buzzing described above.  I was told to reformat my memory card but before doing so I looked at it with a file browser and found three files there that did not belong.  Some sort of system files put there, no doubt, my my Mac when I plugged it in to copy out all my track files.  I deleted the three Mac files, put the card back into the unit, and all is good.  Would be great if Garmin recognized that there is another OS out there.
Posted on Jan 08, 2010
I had a similar problem when I upgraded to 3.90. First, after upgrading, my gps would not restart. Just by chance, I took the SD card out and the unit started up without problems.
When I put the SD card back in, the unit would shut off, but would make the buzzing sound you describe until I removed a battery.
Finally, I completely reformatted the SD card and reloaded all of my maps. This seemed to take care of the problem.
Posted on May 27, 2009
  • bertafloyd May 27, 2011
    Well done, I have removed the sd card and copied the content. I formatted the card and reloaded the folders and the problem was solved.
Hello. Downgrade to the firmware to 3.70. It works for me !
http://www.gpsinformation.org/perry/gps60/
download and install : GPSMAP60Cx_370.exe
Posted on Apr 04, 2009
    New Friend:
When reformatting the card what format do you use? Fat32?
Posted on May 08, 2014
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
Apr 02, 2009 | Refrigerators
Ticking noise while car is running or idling
maybe is the air compresor and that's the noise that you hearing. Put the air in off if the noise stop, your problem is the compresor.
Nov 14, 2008 | 1999 Nissan Maxima
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Zapping sound when turn on
Same buzzing sound here...help!!!!!!!!!!!!!!
Apr 06, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Toshiba 62hm15a
my tv was making a similar sound so i took off the back. There was a bundle of wires that had come loose and were rubbing the fan blades. I retaped them back and no more noise. seriously.
Jan 20, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Loud Buzzing Sound
since you changed the lamp my next thought is that the color wheel has failed,,,most good road techs can replace it in the home..the cost would be between 220.00 and 350,00 depending on the company...
Nov 27, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Garmin GPSMAP 60CSx GPS Receiver Logo
1,575 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
