Question about Craftsman Air Tools & Compressors
CRAFTSMAN 25 GAL,1.6 HP COMPR. AFTER 1ST CYL WONT START BACK UP
I NOTICE AFTER IT GETS HOT AND TURNS ON THE MOTOR LOCKS UP. BUT THE PRESSURE SWITCH WILL BLOW OFF AT 165PSI. IT SHOULD JUST TURN OFF NOT LEAK. IF I MANUALLY TURN IT OFF BELOW 30PSI I CAN START IT NO PROBLEM.
  • jsims53 Mar 11, 2009
    I fixed the problem after a little more playing, it ended up being the pressure valve on the tank sticking and bleeding off the tank and not releasing the compression off the pistions.
  • 398 Answers
The regulator on this model is know to go bad alot, probably needs replaceing. go to sears wbsite to order the part
Posted on Mar 02, 2009
Compressor wont start just hums
Could be a seized compressor, a bad start relay, or a problem with the pressure switch or a bad motor.
May 28, 2012 | Craftsman 3 gal. Air Compressor, 1 hp,...
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Air compresor Craftsman 921.153101 it spound like is one but it wont run at all. It sounds like the motor is stuck
if its belt driven ,unplug it(safety first)remove the belt and try to turn the pump by hand.if the pump turn plug it back without the belt. and try it .if the motor doesnt run.check the contacts on your pressure switch.if they are ok and try again.if not you need a new motor.if the motor ,the pressure switch contacts,and the pump are fine.put the belt back back on bleed your tank to zero with an air gun and try to run it.if it work well till it cuts of check if your bleeder release air.you might have pressure stuck in your pump.the compressor needs to release pressure for a soft start.hope this help!
Apr 17, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
My Craftsman air compressor is locked up. When you turn the switch on it just makes a humming noise and thw motor will not come on.
1. While the compressor is unplugged, see if you can turn the motor freely with a screwdriver or something to determine that the motor is not jammed 2. If there is a removable cover, check to see if the brushes are worn, (replace if needed). 3. There is also a relay that tells the motor to start located near the pressure adjustment. If this relay is defective or the contacts are burnt, you may need to replace the relay. Good Luck!
Nov 15, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Air pressure does not go over 25 psi I have taken the whole unit apart and check, relief valve,regulator,check valve. Pressure switch, Piston & Gasket. everything seem good I have taken the pressure...
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Mar 07, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sears craftsman 3 gal/1.5 hp air compressor won't run
are you using an extension cord? if so, plug the compressor into a wall socket, if it fires up fine then your extension cord is too long or not heavy enough - other problems could be a bad start capacitor, a loose connection in the pressure switch, or a bad switch
Aug 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
79 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
