Question about Indesit W 123 Front Load Washer
Error F10E comes on my indesit WIE1375 washing machine what does this mean?
  • 75 Answers
First check that your drain pump is working,reset appliance and put on drain only,listen for the pump to pump of hum,if it hums there is a blockage,remove filter and check,this is discribed in you manual
Posted on Aug 02, 2009
What does code F-10 means?
F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
Oct 03, 2016 | Indesit Washing Machines
F06 error on indesit WD 61451 washing machine
Could be the program select error, but why not check all error codes and save them on the Indesit site yourself.
Error Codes Indesit Service
Feb 25, 2015 | Indesit Washing Machines
What Indesit WIL 145 Flashing LED red,#1,#2,#3,#4 and 9h. Error?
It looks like an error F15 what means drying heating element earth leakage or relay contact sticking.
Dado
Oct 16, 2014 | Indesit Washing Machines
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Indesit WIE157S washing machine
hi you will find that your pump is blocked and the whole drainage system needs cleaning good luck and unplug regards jason
Jun 15, 2008 | Indesit W 123 Front Load Washer
Error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Jan 03, 2008 | Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Error codes
when the power is turned off for a period of 30 mins and then restored does the machine still display this error code as soon as you try and start the machine,o and by the way does the door lock?
May 03, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
132 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
