Question about Epson Stylus DX6050 All-In-One InkJet Printer
E-04 problem. doesn't appear to be any paper jammed. Fix?
E-04 problem. I cant find any papered jammed. The paper is grapped down towards the right when printing starts and then ...nothing
PUSH FRESH SHEET A4 FOR ROLLERS TO GRASP.IT CLEARED MY BLOCKAGE. TRY SLIGHTLY CRINCLING THE PAPER TO ROUGHEN IT UP IT MAY PUSH BLOCKED PAPER OUT
Posted on Apr 07, 2009
I have a Dell 5100cn and I'm getting paper jam check tray, it seems that when it goes to pick up the paper it can't
077-907 Paper Jam - Push Side Button:
  1. Turn the printer off using the power switch on the right side of the printer.
  2. Press and hold the up and down buttons while turning the printer on. ...
  3. Press the down arrow until IOT DIAG appears, and then press Select ( or ).
  4. Digital Input appears on the LCD, press Select ( or ).
More items...
How to Troubleshoot Internal Paper Jam or Multiple Sheets ... - Dell...
or try this link...
how to fix paper jam Dell 5100cn Google Search
Oct 27, 2017 | Dell Office Equipment & Supplies
How to fix error code 5100 for canon ip6320D. it appearing while head cleaning.
This is either due to a physical error caused by a paper jam, or incorrectly seated ink. To fix:
Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Jan 21, 2011 | Canon Office Equipment & Supplies
Paper jam hp laserjet 5200
All printers after sometime the rollers start grapping more than one sheet that result in paper jam or dirt building up inside…make sure you open the printer and clean it good and see if you can locate any small papers that usually stuck inside…let me know
Please do not forget to rate the service for the site to continue helping everyone and improve on it.
Sep 16, 2009 | HP LaserJet 5200 Printer
Paper jam
Use mirror and flashlight to look down paper feeder from the rear, gently pull paper toward the rear. An index card can be fed from the front to the rear to push paper out by turning the gears you see on the left side inside the front cover. Be careful not to force anything.
Jun 19, 2009 | Canon PIXMA MX310 All-In-One Printer
242.13 paper jam error We cannot find any paper jammed in the paper
hello,
The paper jam error 242.13 can be caused by an actual paper jam in the printer but since you did not find any paper the next thing would be pickup rollers. The pickup rollers can become worn and if they don't grap the paper right it will not more from the tray. There is a sensor that tells the printer that the paper exiting the paper tray and to start the printing. If this sensor does not detect paper when it should be there it gives a "paper jam" error thinking the paper is jammed. Look at the top page of paper for 1 or 2 light gray marks. If you see them then the rollers are the problem. You can see the rollers if you turn the printer on its side and remove the paper tray. To test the pickup rollers you can take off the rubber rollers( they look like white rubber band) from the wheel and turn them inside out, this will work as a temp fix untill you can get them replaced. If you need them replaced we can provide them or you can call a local repair show. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 18, 2009 | Lexmark T644 Laser Printer
E-04 Clear Paper Jam, no paper in printer
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 15, 2009 | Epson Stylus CX7800 Color Flatbed...
Epson cx7800 error e-04
make sure the ink cover was down tight. Shut down the printer open it up and resecure the ink cover. That has fixed this error in many a case.
Jul 31, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Printer
If it is not pushing the paper out of the tray, you should first try taking a soapy cleaner like fantastic or formula 109 and clean the feed rollers and see if that helps.
The paper tray also lifts up and down to feed the paper so the gear that drives the tray up and down may be broken.
Slen the rolls first. If that doesn;t last long. Say in a day or two it starts misfeeding again, the rollers will need to be replaced.
Mar 23, 2008 | Office Equipment & Supplies
Paper jam
please give more info. do you see the paper? does it say paper jam when just turned on? does it feed then jam?
Nov 08, 2007 | HP LaserJet 1320n Printer
Paper jam lexmark x3470
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
Oct 16, 2007 | Lexmark X3470 All-In-One InkJet Printer
Epson Stylus DX6050 All-In-One InkJet Printer Logo
300 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
