Question about Dell Dimension 3100 PC Desktop
Replace the power supply and nothing happen
I replace the power supply and nothing happen
  • scorpionbluf Feb 27, 2009
    reseat the memory blow out any particulars that may have been there and put it back on oand nothing happen
    President:
  • 2,653 Answers
The motherboard is probably bad. Do you get any led's or any signs of life?
What else have you tried so far?
Posted on Feb 27, 2009
  • RescueTechLA
    RescueTechLA Feb 27, 2009
    Have you tried resetting the bios? Or taking the cmos battery out for a few minutes?
    If you have a video card, try reseating that as well.
    If not, it's probably a bad mobo. :(
My motherboard is dead replaced power supply still nothing
you may got a power spike if so board bad look at the board the caps are they round or flat if rounded on top bad board
Jan 13, 2013 | HEWLETT-PACKARD Hewlett Packard GV34469001...
How do I know if the power supply is bad on gateway gt5676 computer? I push power button and nothing happens. I unplug it and the green light flashes on the power supply( Bestec ATX 300 12 EB3). Plug it...
u can buy power supply testers, just a device you plug the power supply into, or try a new power supply. but if nothing is happening no fans etc theres a good chance its just the power supply.
Jun 17, 2012 | Computers & Internet
What is most likely the problem when I push power button and I get nothing, no response at all, Power supply or Mobo ?
First of all, I'm assuming that you've connected everything correctly. I would think if absolutely nothing happens, it's probably the power supply. If a motherboard is bad, the power supply will still flip on, you'll hear the fan, and then nothing will happen. So your best bet for fixing this is replacing the power supply. Possibly with one that has a higher wattage.
Jul 29, 2011 | HP Computers & Internet
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
I have an Intel D865GBF motherboard in my PC, which stopped working. I replaced the power supply because there was no power to the board. Now I have power, but when I hit the power button nothing happens.
The exact same thing happened to my D815EAA2. In my case an overheating power supply destroyed the board. Do the following:
1. Check the power supply you replaced it with works on another system.
2. If it still doesn't work with your board, the board will need to be replaced.
Nov 20, 2009 | Intel D865GBF Motherboard
Emachine T3624 will not power up
Emachines are notorious for having faulty power supplies. If your lucky you just need to replace the power supply. I've seen a lot of them where the power supply also fried the motherboard.
Please don't forget to rate this solution.
Jun 15, 2009 | E-Machines T2984 PC Desktop
Desktop powers up, but just clicks and nothing else happens
It maybe the power supply, if it is you should get nothing no lights clicks would be from the power supply.
Mar 15, 2009 | Gigabyte Computers & Internet
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Gateway desktop troubleshooting
you have a bad power supply. You need to get it replaced.
Oct 25, 2007 | Computers & Internet
Dell Dimension 3100 PC Desktop Logo
Alun Cox
