Question about Sony Playstation 3 (PS3) Console
Backing up data
I want to backup my data that is on my ps3 but i don't know how to
  • richard slater Feb 27, 2009
    ps3 wont update downloads so i cant play call of duty 5
    President:
  • 2,653 Answers
I can tell you.
Posted on Feb 27, 2009
  • RescueTechLA
    RescueTechLA Feb 27, 2009
    Go to SETTINGS, SYSTEM SETTINGS, BACKUP Utility.
    Follow the prompts.
    Make sure you have an external hard drive or usb drive with enough space on it.
    That's it. It's kind of slow so be patient.
  • RescueTechLA
    Please don't forget to rate my solution FIXYA
    Thanks!
My playstation 3 wont let me down load soft ware foe call of duty 5
PS3 40gb will not read disc
Check the game disc/discs. If possible, confirm the disc actually works (Try it in another PS3, for example).
Restart the PS3. Then shut down the PS3, unplug it from the outlet then plug it back in (surprisingly this is different than just restarting/shutting down).
Who knows, maybe it's a firmware thing. Update your system to make sure. Go to XMB > Settings > System Update and run it.
And now we get into the scary, probable (and sometimes guaranteed) data-loss solutions. I would suggest backing up your data. Use the Backup Utility (XMB > Settings > System Settings > Backup Utility) to store everything. You can then restore all your data once you fix the issue.
With your data backed up, try the different options in Safe Mode. This link will show you how to access it. Try options 2, 3, 4 and 5, in that order, and see if it's reading discs in between each one. Anything after 2 will delete your data; thus the need to make a backup.
Still no luck? Unfortunately this you're probably going to have to send your console in for repair. Sony provides a form on their website to request a repair; here's a link. If you're under warranty it's free; otherwise it's expensive (150$ I believe). The worst part about this option is they take forever; you won't see your console again (or it's replacement) for at least a month, more likely two.
Hope this helps you get it working soon!
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
Tip
How to backup your Playstation 3 data The steps below will walk you through...
The steps below will walk you through backing up your data on your PS3. This includes any game data and downloaded content like music and videos. Note if you ripped alot of music and/or downloaded alot of content to your PS3 you may need an external hard drive to do the back on. If this is the case you will need on formated to FAT32 and not NTFS.
1. Go to the Settings menu and select System Settings.
2. Select Backup Utility
3. Highlight Back Up and press "X"
4. Next you will get a message asking if you want to continue. You will need to select YES and press "X" to continue. Note as the message states your Trophies will not be backuped as they are saved to your PSN account profiles. The link below will show you how to force an a sync of your Trophies to your online profile.
5. Below is another confirmation message that you will need to select YES on and press to continue. Note this is a message stating some copyright-protected content may not be backup. In most cases this will apply to movies that you have purchases off line. However in most cases you just need to redownload them after you restore your PS3's data.
6. Next make sure that the memory device that you want to do the backup to is selected that press "X". Note if you have more than one device connected that you will get more than one option to do the backup to.
Also if you get this message then there was not enough space to do the backup to. Like I mention above you may need to have an external hard drive to do the back of your data because as you can see below this backup needs 48GB of space to fully do the backup.
Once this screen comes up your backup is running. Note if you have alot of data to backup you will be waiting for awhile for the backup to finish.
7. Now the backup is finished press "O" to go back to the main menu.
Click here for steps on how to restore data to your PS3.
on Oct 09, 2010 | Video Game Consoles & Games
Can i myself fix error 80010514 on ps3
Well this is an interesting one; error code 80010514 implies a faulty installation of your firmware.
If you can still access it, try running the System Update (XMB > Settings > System Update).
If the update didn't work, you should backup the data on your PS3 using the Backup Utility (XMB > Settings > System Settings > Backup Utility). What we're going to do to WILL delete the data on your hard drive, so if you don't back it up it'll be gone forever.
Once it's backed up, turn off the console and start it up in
Safe Mode. This link will show you how to access it. Start at option 2 and work your way down through 5. Each option will delete more and more data; option 5 wipes the whole hard drive, thus why we backed up your data.
I'm fairly confident that by using Safe Mode you'll be able to fix your PS3. But if it doesn't work, there's always the option to send your PS3 back to Sony. It'll cost 150$ if you're not under warranty, and you won't see your PS3 for a month or two, but they should be able to fix it. Here's a link to the Service Request page.
Best of luck!
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
Wont read game discs
Start small; check the game disc/discs. Can you confirm that the disc works? (Try it in another PS3, for example).
Next restart the PS3. Then shut down the PS3, unplug it from the outlet then plug it back in.
No progress? Make sure your system is updated. Who knows, maybe it's a firmware thing. Goto XMB > Settings > System Update and run it.
Still have problems? Now we get technical. First I would suggest backing up your data, as things can and will get deleted in the next couple of suggestions. Use the Backup Utility (XMB > Settings > System Settings > Backup Utility) to store everything. You can then restore all your data later on.
For my ps3 when i start a demo the screen turn black .and when i put a game in the blueray its not spinning what was the problem does its the mother board or what???
The Blu-ray drive is probably broken since you've confirmed it's not spinning. As for why demo's won't play, it may be some sort of security feature (disc drive won't work, therefore assume that games can't be played and disable all other game playing). I'm not sure I'm kind of guessing on this one.
What I do know is that replacing the Blu-ray drive of a PS3 isn't the easiest thing in the world, and there's no guarantee that doing it will fix your console. Your best option is probably to send your PS3 back to Sony for repair. If it's under warranty the repairs will be free; otherwise it's $150. Regardless of warranty status, you won't get back your PS3 for a month or two. You can start the process of sending in your PS3 on Sony's PS3 support website, linked to here.
Make sure you backup your data before doing so! Sony won't save any of it for you. You can backup your data using the Backup Utility by navigating to XMB > Settings > System Settings > Backup Utility. Then just follow the on-screen instructions.
Sorry for the disappointing solution. Hope you either find a better solution, or at the very least it's under warranty and Sony sends it back ASAP.
The back up operation could not be completed (80010012) it comes on evry time i try backing up my data
There is a connection problem. If you are tyring to backup to an external source, it is either connected wrong or incompatible. If you are trying the PS3's own backup, then I don't know what's wrong.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 turns off every time i go to load a game film ect, but it will stay on the home screen al day can anyone help me
Hi
Best this to do is a PS3 full reset, but make sure you back up your game data
Here's what to do:
1. Take disk out.
2. Back Up save data.
3. Back up general data using PS3s backup Utility.
4. Sync Trophies.
Now to do the ps3 reset
Hard Reset procedure for the PS3 (from Sony CS). Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
let me know how it goes.
Mar 15, 2010 | Sony Computers & Internet
Restoring files after using the Backup utility.
1. Plug in the USB drive that contains the data.
2. On the XMB go to Settings then System Settings
3. Go to Back Up Utility like before but
4. Choose Restore rather than Back Up
5. The PS3 does the rest
You can have the PS3 delete the data file from the USB drive by choosing Delete Backup Data.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
Can't restore data after linux install
In my case the problem was that the USB device did not re-mount after the PS3 restarted. Try this:
Start the backup restore process.
Remove the USB device sometime after the PS3 starts formatting
Once the PS3 has restarted, re-attach the USB device.
Wait for a while to allow the device to mount (about 15-30 seconds) before pressing the PS button to continue!
Apr 14, 2009 | Sony Playstation 3 (PS3) Console
The backup utility does not seem to work properly. I have a 40Gig drive and the backup function works as normal, but when I go to restore it says no backup data. I checked on my PC and there are five files...
Try starting the backup restore process, removing the USB device sometime after the PS3 starts formatting, then re-attaching it once the PS3 finishes restarting. Wait for a while to allow the device to mount before you press the PS button.
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
