Question about Humidifiers
Vicks humidifier i just bought a vicks humidifier not even a month yet and the steam is not working anymore even we put a pinch of salt still not working. i always change the water everytime we used it. please tell me what im gonna do. thank you so much and looking forward for your answer. eva
Even though you change the water every time, if it's like ours you will still need to clean it with vinegar about once a week. I have a container that the insert portion (filter or whatever it's called) will sit in and has just enough room to pour in 4 inches of vinegar. Let it sit for about 10 to 20 minutes and then run water through the part where the mist comes out while holding your hand over the bottom. After a few seconds allow it all to run through. Continue and shake it really good and continue on until it is clear. I was AMAZED at what came out the first time I did this and part of the time I used distilled water. Hope this solves the problem.
Posted on Mar 01, 2009
I have hard water, plugged it in, no steam. Added salt, no steam. What to do?
I have hard water as well and I wasn't getting steam. I put in a good tablespoon of salt and the steam started immediately. Try more than a pinch (if that's all you put in originally)
Oct 16, 2012 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Do I add salt with the water when using this cool mist humidifier
Hello
Ive been down this road before,sorry your son is sick.
Take a teaspoon of salt and add it to a full tank,it will break up the corrosion on the heating elements,a teasspoon of baking soda will help also.
This will not hurt anyone if it blows into the air with the steam.
May 12, 2010 | Vicks Healthmist 4100 Humidifier
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Dec 24, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No steam output
Dec 06, 2009 - found solution: if unit is truely clean, unplug unit then mix about a teaspoon of iodized salt (table salt) to the water. Reconnect unit wait about 1 - 2 minutes, unit will start to make a grinding sound but shortly after steam will produce.
Nov 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Why is it that the steam doesn't seem to be working very well.It is a Vicks Humidifier.
use vinegar in water when steam drops then clean out water container. and use a small pinch of salt to let the two prongs in the plastic tube make better contact with each other it will steam very well.
Nov 09, 2009 | Vicks V150SG 1 Gallon Humidifier
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Humidifiers Logo
397 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
