Question about Remida Automatic Citrus Remuk4 Juicer
Citroen xantia fuel pump relay
My xantia suddenly cut out and after checking everything else figured i couldn't hear the fuel pump when i turned on the ignition i just dont know where the relay is.It's a 1996 citroen xantia 1.8 petrol thanks.
  • 600 Answers
If you have enough fuel pressure the pumpl will not allways run anyway, carefully slacken a fuel line on the pressure side and see if fuel weeps. Get someone to try and start and see if you can hear the injectors clicking, also check spark (up to this year the fuel injection was a part function of the ignition, if the module in the distriputor goes down you get no fuel either.
Posted on Aug 16, 2009
2 Suggested Answers
sywright
  • 112 Answers
SOURCE: my xantia suddenly cut out and after checking
Yr realy is in the plastic box which hoses yr ECU. This is normally under the bonnet on the drivers side.
Posted on Oct 28, 2009
Juicer vibrates
THE SOLUTION TO VIBRATING. If it spins up ok and starts vibrating suddenly as you are feeling it, here's the solution: feed it very, very, slowly. that's it. i couldnt figure mine out, then realized that if i fed it slowly, it was just fine.
Aug 16, 2013 | Omega 1000 Juice Extractor
I took my juicer apart and now I am trying to re assemble it but I don't know where the springs go. Please help
they attach to each side of the metal bar. i threw the springs away because i couldn't figure out where they went, and now the unit shakes like crazy :) but i read up on it and found out the springs go on each side of the bar i think. 50 bucks will replace the bottom part of the machine (base and motor) https://www.unitycart.com/pjss/parts/parts_classic.asp
Jul 26, 2011 | Jack Lalanne Power Juicer 250 Watts
My micro wave unit sounds like its running but will not hear.Lites, motor , vent , clock , everything seems ok but will not heat
Hi
Thanks for using FixYa. Many things can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 18, 2010 | Juicers
Motor won't work on Champion unless I press on part
it probably has developed a loos connection inside. Pressing on that part reconnects the loose connecion inside the machine. If you are someone with a good mechanical aptittude, you may open it and somehow make a hood connection again. The problem should be obvious, and straight forward to fix.
Jun 27, 2009 | Champion G5-PG-710 650 Watts Juicer
Flashing sidelights on citreon xantia M reg
There's a button with a speaker with a cross through it on the dash to the right of the steering wheel.Should be the furthest button to the left.Turn yr ignition on and within 10 seconds press and hold this button till the indicator lights flash on the dash.Problem fixed.
Jan 14, 2009 | Remida Automatic Citrus Remuk4 Juicer
Please help me
Phone Citroen Glasgow with your VIN number, they will provide a radio code.
Apr 06, 2008 | Remida Automatic Citrus Remuk4 Juicer
How to take apart
I hate to admit my wife was right:  "Don't get it.  It's too cheap.  You get what you pay for!"  Gaads, I hate to admit this THIS time, she might have been right!  I am going back to play with it to see if I can figure it out!  There's gotta be a way to clean it!  Otherwise, it is just a salmonella breeding laboratory!
Oh-oh!  I just found it - (after I cut one of my fingers on the cutters looking for access!)  Here is the answer:
1.  Do NOT turn the basket/cutter part.
Just because there is a knurl on the cutter basket doesn't mean we put our hands on it -- yet!
2.  Turn the entire TOP in which the cutters nest approximately 60-90 degrees CLOCKWISE.
3.  Lift the entire plastic assembly straight up.
4.  The cutter basket will now separate from the plastic top.
Good luck -- and don't cut yourself, unless the taste of your own blood excites you!
Feb 12, 2008 | Brentwood JC-250 Juice Extractor 350 Watts
Remida Automatic Citrus Remuk4 Juicer Logo
416 people viewed this question
Top Remida Juicers Experts
eyecam
David Payne
David Payne
Are you a Remida Juicer Expert? Answer questions, earn points and help others
