Question about Insignia Digital-to-Analog Converter for Analog TVs
If the converter box different from yhe television
Does it matters if your converter box matches your t.v. or not
  • Anonymous Mar 02, 2009
    I have a zenith converter box and my Dvd is an amw it wouldn't matter if they are too different items does it
  • 26 Answers
No.
The converter box converts the digital signal to analog and feeds it to the TV.
The only reason for the box to be the same manufacturer is if you want to keep all your equipment the same make.
It does not matter who makes the box.
Posted on Feb 28, 2009
What model of a conveter box do I need to set up the TV ?
Different TVs need different type of converter box to work properly. If your TV has audio video [A/V] input socket, go for a converter which has A/V output in it. If your tv has no A/V input, and only one ariel socket is there, buy a coverter which has RF output in it. Most of the coverters have both A/V and RF. Just buy that type of converter and it is good for you if you are not sure about the matter.
Oct 16, 2010 | Craig CTV-41331 13" TV
Does my curtis mathes tronics tv model CM19011 made in June 2000 have a digital tuner as needed to currently view tv over the airwaves?
No,all CRT tube tvs don't have digital tuner inside.They're analog tvs.Must buy the converter box,and hook it up to get the free DTV airwave signal.Trust me,i help an elderly person hook up this exact this tv model with a converter box.Try buy the RCA model converter box,it matches with this tv model very well.
May 15, 2010 | Curtis-Mathis CM19011 TV
Cable converter box - video not matching audio
SAP secondary audio program is activated .it has to be turned off with the menu controls
Aug 19, 2009 | Televison & Video
Converter box
put your tv on channel 3 , and make sure the back of the "converter boxes switch" is set to channel 3 not 4 if using the coaxial antenna connection to the tv
if using the video and audio jacks then the switch on the box will not matter
Mar 14, 2009 | Televison & Video
Converter box issue
Beginning February 17th everyone getting their channels over-the-air (antenna) will need a converter box to continue receiving their channels; doesn't matter what kind of TV they own. You can go to https://www.dtv2009.gov for more information and to request coupons to receive the converter box
Dec 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
Digital Transition
If this a digital ready TV, you won't need a converter box at all.
If not, the converter box is designed to work with all TV's.
Greg.
Aug 14, 2008 | Televison & Video
Digital converter box setup
Hi Kilroy75,
It sounds like you probably set this up properly. The converter box is powered on, indicated by the blue light (it is illuminated red if powered off). I would recommend that you check to see if your TV has to be on a specific channel to receive external input.
To double check the connection, you should be able to follow the antenna into the converter box, then the converter box into the TV. Check to make sure you have input/output correct, and that video matches video, audio matches audio, etc.
Also, some antennas require power. If this is the case, make sure the antenna is plugged in and powered on.
If none of these suggestions help, I would try a little troubleshooting to determine which piece of equipment is giving the problem. Try connecting another device into the same input to see if your TV receives signal through input 1. You may also try a different set of A/V cables or a different input on the TV.
If you still are unable to get your setup working, I recommend you bring the converter box into your local Geek Squad® precinct for further troubleshooting and advice.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 25, 2008 | Televison & Video
Upgrades
The DTV converter is only required if you use an external antenna. If you have cable or satelite, nothing will change. There are no other options.
Dan
May 23, 2008 | GE 25GT240 25" TV
Insignia Digital-to-Analog Converter for Analog TVs Logo
116 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
