Question about Kohler K-10416-BN Fort½ Single Control Kitchen Faucet with Side Spray...
Faucet handle stuck
Have the cap off top the screw out and it is still stuck. How do I get the handle off?
  • 297 Answers
Most times you need a special tool when this happens,it is called a handle puller. you can buy this at home depot.use as instructed.the handle will come off with ease with this tool.good luck with your project.
Posted on Aug 04, 2009
  • 49 Answers
Try puting boiling hot water on the bottom of handle push down on the handle then pull up .
Posted on Feb 27, 2009
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
I'm trying to remove the handles from my american standard bathroom faucet. It is from 1992 model 908497. I can't separate the part under the sink from the handle. I have it were I can lift it up about 1...
I think you might need a handle remover tool. It looks like two "L"'s facing each other with a long screw going through the top of the two L's . With a T handle at the top. The two L's go up under the bottom of the faucet handle, and the long screw fits into the screw hole for the faucet handle. A dozen turns or so and the handle pops off the valve stem. Cost about 10-15 dollars at any hardware store. hope this helps.
Nov 27, 2013 | American Standard Plumbing
I can not get the handles off. there are no screws
There is either a screw under a cap from the top or a set screw from the side. Looked at about 200 Grohe diagrams and they all have that arrangement.
Aug 07, 2012 | Grohe Seabury Widespread Lavatory Faucet...
I am trying to fix a leaky danza single handle bathroom faucet. I cannot figure out how to remove any part of the faucet from the top to be able to change the washer.
There is a allen set screw on the handle it may have a cap over it locate it and unloosen screw and remove handle then un screw bonnet nut then replacement kits available at most hardware,home improvement,or plumbing stores take note of how the parts are removed so to reinstall the way they came out.
Jun 05, 2011 | Danze D203112 Melrose Single Handle...
My moen bathroom sink handle came off. The srew into the handle comes up from the stem? how do I access the srew to reinstall handle? Thank-You
pop the cap off top of handle with steak knife, screw is underneath,unless yours is like the one pictured,then its an allan screw from the back.you had one when it was installed and,these can be really stuck
Jan 28, 2011 | Moen Bathroom Sink Faucet - 4-inch...
How to take the faucet hander off
Remove the cap and expose the screw. Unscrew and remove handle. If it is stuck on you can buy a faucet handle puller at any hardware store for 8 - 15 dollars.
Dec 24, 2010 | Kohler Efficiency Kitchen Sink Drop In...
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I have a loose handle on my Moen two hanlde lavatory faucet and i can't find any set screw to tighten it . How to tighten the handle to the faucet stem?
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
May 03, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do I remove the handles from the faucet? I cannot locate a screw. Thanks.
Does it have plastic or metal handles some have caps on top covering screws that hold handle on faucet.
May 02, 2010 | Grohe Classic Kitchen/Bar Faucet ...
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Kohler K-10416-BN  Fort½ Single Control Kitchen Faucet with Side Spray... Logo
1,120 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
