Question about Canon PIXMA MX310 All-In-One Printer
I installed canon mx310 and got connected but it will not let me print When I try to use it, I get a message saying "The printer is performing another operation". I have re-installed more than once, and been in touch with Canon. I have also tried it on another computer and the same thing happens.
  • cadsbrooker Feb 27, 2009
    Premier assistance worked after nothing else did.
  • 3 Answers
Try to restart your pc.
Posted on Mar 01, 2009
Screen saying scanner error
You can try uninstall and install printer driver or try a known good connectivity cable.
Dec 13, 2012 | Canon MX310 Office All-In-One Printer
Canon MX310 - I'm trying to connect this printer to my network. Currently, I have the printer connected to an Airport Express but when I try to print from my iMac, I get a message that the printer is...
Adkinsdave, keep in mind that often having someone remotely connect to your computer with you and perform this task is easier than trying to walk you through steps and potentially missing a step. With that being said, the Airport Express was meant to make setting up a WiFi network in your own home a breeze.
We need to first determine if your Canon PIXMA MX310 has a Mac driver. According to the Downloads page at Canon.com, there are several Mac drivers available for OS X, 10.5 and 10.6: usa.canon.com - simply choose your OS on the pulldown from that website. Once your computer has the driver it needs to communicate with the printer, you can use your Airport Express to connect to the printer.
Obviously, make sure the printer is turned on and once you go through the Airport Express connect guide you should be printing in no time.
Let us know if there are still issues.
Nov 13, 2009 | Canon PIXMA MX310 All-In-One Printer
CANON PIXMA MX310: printer not responding.
If you go to Start, Printers and Faxes, if it says "Offline", right-click the printer and choose "Use Printer Online." If it says Ready, you should be good to go.
If however there is a problem yet, double-click the Printer there and see if any jobs are in the print queue. You can remove them all buy Right-Clicking and choosing "Cancel All Documents" then try printing a test page. Right-click the printer, go to properties and click "Print Test Page."
If you still have problems, follow up on your question.
Aug 29, 2009 | Canon PIXMA MX310 All-In-One Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
My Cannon Pixma MX310 has "received message" in fax, but I have refilled cartridges and the printer says "ink low", I would like to print fax messages in the machine, or is there any way I can look at them...
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Jan 07, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot print from Apple MacBook to Canon MX310
First, check your USB printer connection to your Macbook from your Pixma MX310 printer.
If the USB cable is securely seated, make sure you have installed the updated drivers for your version of Mac OS X. Here is the Link:
Canon Pixma MX 310 Drivers for Mac OS X (v10.6/10.5 and earlier).
If you have already updated your printer drivers to the most current Canon Pixma update for your version of Mac OS X, then click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences.
• From System Preferences, select Print & Fax.
• Within the Print tab, make sure you can see your Canon listed in that window.
If you can, proceed to perform a test print on any document you have on your desktop or folder of choice. If this does not help, from within the Print tab, select the Canon and press the "-" Minus button and remove that printer.
• Once it is removed, now click the "+" button
and re-add your printer.
• Once it has been added, attempt to test print again.
This should help get your printer back to printing again.
Regards,
-Mactechtrainer
Dec 02, 2008 | Canon PIXMA MX310 All-In-One Printer
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
348 people viewed this question
old marine
old marine
