Question about Brother MFC 9700 All-In-One Laser Printer
Scanner instructions I have had a Brother MFC 9700 for several years but have never used the scanner. Now I need to fax a 3-page letter to New Jersey. Where can I find SIMPLE instructions?
  • 82 Answers
How can i print out what did i fax
Brother MFC's usually come with some version of the ScanSoft software. One of it application is called pageviewer. View the fax through page viewer.
Besides, if you faxed from the computer, the original file must be on the computer. Launch a search for it.
Dec 20, 2012 | Brother MFC 9700 All-In-One Laser Printer
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
I have an older machine: model MFC 9700. It has stopped receiving faxes and is showing an error message 71. Says to unplug and call Brother. Is this worth repairing? or smarter to invest in new...
Thats up to you. request a repair cost and compair it to the cost for a new one. Your choice mfc 9700 is a good unit. Upgrade to a MFC 4100n its one of the best brothers makes. Hope this helps.
Aug 12, 2010 | Brother Office Equipment & Supplies
Canon printer 5440 "unable to print see troubleshooting routine maintenance manual" - message in led window
Open the scanner cover and remove any
foreign obstacles from inside the MFC. If the
error message continues, please follow the
steps below before disconnecting the MFC so
you will not lose any important messages.
Then, disconnect the MFC from the power
source for several minutes (which will erase all
faxes), and then reconnect it.
Check whether the MFC has faxes in the
memory
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
OR
If faxes are present, you can transfer them to
another fax machine. Go to Step 3.
OR
You can forward the faxes to your PC. Please
see Transfer faxes to your PC.
Transfer faxes to another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3. Enter the fax number to which faxes will be
forwarded.
4. Press Black Start.
5. After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set,
9, 0, 2 in Step 1.
You can move the faxes from your MFC’s
memory to your PC.
1. Press Menu/Set, 2, 5, 1.
2. Using ▲ or ▼, select PC Fax Receive, and
then press Menu/Set.
The LCD will ask if you want to transfer a fax
to your PC.
3. To transfer all faxes to your PC, press 1.
OR
To keep all faxes in the MFC’s memory,
press 2.
4. After the faxes are transferred, disconnect
(For details see Using Brother PC-FAX
software
on page 5-1 in Software User’s
Guide on the CD-ROM.)
These steps is on user manual.
Jan 16, 2010 | Brother MFC-5440 Printer
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
If you press Black Start, the
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother 9840CDW won't scan/fax legal size pages from glass or ADF
Is a setting in the printer.
Go to start >Brother> start center> on top go to configuration. then it will ask you for a password. use "access" for the password.
click on general setup and you'll see document scan at the bottom.
Change it from letter to legal and apply.
Voila!
Sep 02, 2009 | Brother MFC-9840CDW Laser Printer
I need to resend busy faxes with my MFC 9700
Yes, scroll through the set-up menus and set Number of Redials
Mar 06, 2009 | Brother MFC 9700 All-In-One Laser Printer
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 9700 All-In-One Laser Printer Logo
109 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
