Question about Nilfisk Vacuums
Nilfisk advance carpet cleaner ax400
Am looking to download parts and instruction manual for a nilfisk advance ax400 carpet cleaner
CompuGuy44
  • 432 Answers
SOURCE: Instruction manual for 8910 proheat cleaner
Heres the website to download the manual. http://www.bissell.com/images/UserGuides/1699_306.pdf
Posted on Jul 20, 2007
SOURCE: Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Posted on Sep 20, 2008
SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
Posted on Jan 08, 2009
SOURCE: Carpet steamer continually sprays water/cleaner. Can't stop it!
This is a solution for the Bissell Pro Heat, although it may apply to other Bissell steam cleaners as well. This is for the problem of the cleaning solution continually spraying without stop.
I found a quick and simple solution to this problem.
This problem occurs because the valve that allows the solution to flow gets "sticky" and will not close. The valve is engaged by the trigger mechanism in the handle. Squeezing the trigger pushes downward on the valve's plunger, but the spring in the valve that is meant to push the plunger back up to the closed position is not capable of doing so.
Here's the solution:
This valve is white and resides about half way down the vertical handle portion of the cleaner. To get to it, unscrew the 2 black screws that hold the top part of the handle to the bottom part. These are the same screws that you used for assembling the cleaner when you first bought it. Pull the top portion of the handle up and it should slide out.
Now, looking down into the handle body of the remaining portion of the handle, you'll see the top of the white valve. If you push down on the top of the valve (like the trigger mechanism in the top part of the handle you just removed does) it may go down some, but it probably won't go back up by itself like it should.
I found that lubricating this plunger with dish soap was the trick. If you can't get enough access to the valve to do this, you can remove the seven phillips head screws in the lower portion of the handle and pry it apart. I did this. I even took the valve out and put soap around the plunger and into the valve itself. I worked it up and down until it had a quick and positive open/close action.
Reassemble and you should be good to go. You'll notice that the trigger now has a more positive feel to it. I hope this helps.
Posted on Jul 25, 2010
  • 42 Answers
SOURCE: have a bissell powerwash proheat carpet cleaner
Go to the following site and enter the product name or model number:
http://www.bissell.com/user-guides/
Posted on Jul 25, 2011
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
Nilfisk BR1100S
http://webparts.nilfisk-advance.com/pdf/OM56041978-US,TR.pdf
This is the manual, if it ain't there, good luck. (Check A-4 and A-5):
BR1100S, BR1300S
INSTRUCTIONS FOR USE
May 07, 2014 | Vacuums
Please show me instructions on how to use Hoover model#f5858-910
Sorry they don'nt have a manual for f5858-910 but if you go to this link below and click on a machine that looks like your's you can download the manual for that model , it mite give you some ideas,,
http://hoover.com/search/?q=spin+scrub&x=9&y=7
Nov 29, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
No instruction manual for bissel powerlifter carpet shampooer
go to this link:
http://www.bissell.com/customer-support/
there is a spot to put your model number in and you can download the owners manual. Good luck! Regards, Ross
Sep 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
I need Bissell POWERSTEAMER® PROHEAT instruction manual
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hdf
May 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I need the catch that holds the accessories lid down on a nilfisk x300 vacuum cleaner. it also forms part of the handle. Where can i get the part and what is it called
Hi there SmartAlec from NelsonVacuums.com.au here. The part for your nilfisk x300 is called an accessory lid lock part number 1470184500. I am a nilfisk dealer so i can help you in getting this part. I think it is about $12. I will list it for you on my website NelsonVacuums.com.au or send me an email and i can organise an over the phone transaction. Hope this helps.
Happy Vacuuming! :)
Aug 18, 2009 | Vacuums
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Vacuums Logo
101 people viewed this question
Top Nilfisk Vacuums Experts
Jim Parker
Jim Parker
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
