Question about Sub-Zero 632 / S
Need to move Sub Zero fridge Model 532 out from cabinet-framed opening. Don't have owner's manual readily available. What are the instructions on how to move it and how to slide it back in and level it. I see the drop-down wheels/rollers and leveller under the fridge but want to make sure my kitchen people do this correctly. Thanks
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
SOURCE: light switch does not work
1. Check to see if the bulb has blown.
2. Check the plunger switch is making contact. ( the light must be on when the
door is open meaning that the plunger is sticking outward. the light should go
off when you press the plunger in)
Posted on Feb 02, 2009
SOURCE: Removing Door Panels on Sub Zero 532
Hi, there is a metal strip that runs down the middle of each door the entire lenth. It is held on with two magnets. Once you pull that strip of metal off, you will see five screws that hold the door handle on. Remove thos five screws and the entire handle comes free. Slide out the panel and replace the handle, screws and metal strip ion reverse order. Take your time removing the magnetic metal strip as it is a very soft metal and could possibly bend or kink up on you.
Hope this helps. I'm having some trouble locating any company that makes stainless stell to match the appliances. All of the metal companies say the appliance manufaturers have a propriety type of lock on the appliance metal finishes. I also have the 532 model.
Good Luck
Posted on Apr 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: 532 sub zero evaporation tray is filling up with a
This is only normal in an environment of high humidity. My question is the condenser fan blowing over the condensate pan and is the air hot enough to evaporate the water that is in the pan? Has covers been removed on the rear of the refrigerator that may cause a different flow of air. Are all covers in there correct place and not missing panels that could change the flow of air over the pan? Let me know, Thanks, Sea Breeze
Posted on Aug 26, 2009
  • 12744 Answers
SOURCE: sub zero 532. freezer works fine --0 degrees.
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Posted on Jun 28, 2010
Testimonial: "thanks for the help - I will check all your suggestions "
I need an owners manual for about a 2009 olevia 32 inch lcd tv and for the remote also.
Olevia 527V User Manual
This manual is for all the Olevia 5 series tvs(526,527 and 532). Around page 30 it shows instructions for the 532 remote.
Feb 22, 2017 | Olevia Televison & Video
I have a sub-zero model 532 that is missing the ice bucket!! I need that part but cannot find it. HELP!!
7016093. Thats the part number for the ice bucket but I think it may have been discontinued and not available anymore. There is a place called K and N in Houston Texas that may have one or can send you in the right direction. Their number is Houston - (800) 782-4518
Austin - (512) 339-8300
May 03, 2012 | Sub-Zero Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Power requirement sub zero 532
115 volts on a 15 amp circuit
May 19, 2009 | Sub-Zero 632 / S
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Jan 19, 2009 | Sub-Zero 561 / F
Sub-Zero 532 not cooling
Simple think I guess - just pull down a little a plastic fan blade on motor shift it will produce a powerful air flow. Fan blade should sit pretty close to the shift end. ;)
_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jun 11, 2008 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
903 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
