Question about Western Digital WD2500JS 250GB SATA2 7200rpm 8MB 250 GB SATA II Hard Drive
I have a westerndigital HD(WD2500JS). This HD is suppose to be a 250G HD but I'm only getting 8G. There are no jumpers currentl installed. I'm thinking I should have one installed but I'm not sure where. Any suggestions?
2 Suggested Answers
  • 10406 Answers
SOURCE: my mb Asus K8N cant start using HDD WesternDigital WD3200AAJS
Unplug your computer.
On the end of the disk-drive, there is three-by-two grid of gold pins, labelled MA(ster), SL(ave), and C(able)S(elect). Move the jumper to the 'CS' position.
Start your computer.
Press DEL to enter BIOS SETUP.
Use "auto detect IDE drives", and the 160GB drive should be recognized.
Posted on Apr 24, 2010
Putting this drive in a dell, I,m Not familiar With the Jumper settings,SSC,PM2, Opt 1, opt2, i,m use to CS, Slave,Master ETC
http://wdc.custhelp.com/app/answers/detail/a_id/1400#jumper
http://www.overclock.net/faqs/99291-info-what-ssc-jumper-my-hard.html
Jun 09, 2011 | Western Digital WD2500JS 250GB SATA2...
Need hd parameters to manually install my wd2500js sata drive.
Unless you have specific reason or odd hardware then then for most purpose setting the BIOS on a comuter to AUTO for the hard drive is all that is needed.
If the BIOS fails to see a SATA drive then in most instances there is an issue with the drive itself or it has had the settings changed at a low level.
In both those instances the settings for the drive itself would be of no help to you.
However if you really do need them they are available here.
http://www.wdc.com/wdsearch/?sc=&sl=en-US&sq=WD2500JS&Go=Go
Feb 04, 2011 | Western Digital WD2500JS 250GB SATA2...
250g wd hard drive quit working, bought an identical HD,installed original backups that I made when I bought the HP 1195c win xp media center. I bought an external enclosure and connected it. The only...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
??????????????????????????????????????????? hope this helps
Jan 08, 2011 | Western Digital Computers & Internet
Hello sir, i recovered some imported data from my corrupted hard disk (WD2500js) but after that i could not install the windows on it. I have partitioned it three times but didn't affect. i think i need a...
I think that your disk-drive is about to "die", and the symptom of not being able to install Windows (which tries to write many files onto the disk) is a strong indicator.
Is the drive still under warranty? If so, W.D. will give you a free replacement. If not, W.D. has a 'Customer Loyalty' program -- buy a new disk-drive from their web-site, and get a discount.
Oct 25, 2010 | Western Digital WD2500JS 250GB SATA2...
Hi, My previous computer died and I have tried to
you need then to "boot" in the second HD to TRY to look at those files.At start up press F12 and chhose the HD.
Oct 12, 2010 | Western Digital Caviar SE WD2500JS...
My mb Asus K8N cant start using HDD WesternDigital WD3200AAJS
Apr 24, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
Jan 12, 2009 | Western Digital WD2500JS 250GB SATA2...
Intel 2.8G\400MHz problem
I would agree that 50% of the time you may get away with putting a working Hd with windows on it to run when changed to another board. When you change your motherboard, there are certain entries in the system registry that are looking for the components of the old motherboard. If the registry does not find these components, the system can become unstable.
The fact that you got windows to some what start is a good sign for the Hd. Try setting the CD as first boot device & have your windows XP in the drive. Do a format & install. I'm sure windows will install. Since you have three boards all the same you will only have to do this once. Foxconn warrants all Mb for life. You can always call at 580-272-0035
Mach Speed Technologies, Inc.
110 East 10th Street
Ada, Oklahoma 74820
Jan 08, 2008 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Hard drive instalation
To slave the Maxtor you remove the jumper or jumpers
Oct 30, 2007 | Maxtor Hard Drive
New Hd HELP
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Western Digital WD2500JS 250GB SATA2 7200rpm 8MB 250 GB SATA II Hard Drive Logo
175 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
