Question about Acer Aspire 3000 Notebook
Led light on front of notebook stays lite even when not pluged in and not running on the battery
    President:
  • 2,653 Answers
That's usually a motherboard glitch.
You can try updating the bios to see if it fixes the problem.
Acer Download Page
Let me know what happens.
Posted on Feb 27, 2009
  • 3 Answers
Inspiron b130
Have a sony vaio the wont turn on, nor will any lights come on.
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 01, 2012 | Sony VAIO EB Series Notebook
Lost power to turn sig airbag light and heater control.I pluged trailer lightes in to my tow package
The trailer might have a bad ground. My camper does the same thing to my truck. Try directly connecting the trailer ground to the frame of your vehicle. This might solve the problem as it did for me.
Nov 16, 2012 | Cars & Trucks
Cannot bootup . Screen lites up with choices--safe mode,safe mode with networking, safe mode with command prrompt, tart windows normlly. useed up/down keys for eah selection and no results. Should blue...
When you connect the power adapter into the laptop, does the blue power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Jan 26, 2011 | HP Pavilion ze2000 Notebook
Crazzy compaq 6910p when the battery is first pluged in all the lights blink, Only one led stays on and its a green speaker. if i hit the power button the charging light will blink 8 times. the speaker...
Your battery is bad and causing a problem. most likely it is feeding an incorrect voltage into the computer. replace teh battery and it should fix the problem. If you have already replaced the battery with a new one the charging system is faulty or the AC adapter.
Dec 23, 2010 | Computers & Internet
Smartpro UPS dead
APC UPS not turn on if battery are dead (zero volt) or un-plugged.
Oct 16, 2009 | Tripp Lite Lite SmartPro DataCenter 5000HW...
Amber light on front of laptop flashes even with the power off
The Battery indicator LED is to the right of the power LED. Flashing AMBER indicates a fault with the Battery. To resolve, replace the system battery.
Apr 13, 2009 | Dell Inspiron 2200 Notebook
I have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Apr 11, 2009 | Gateway MT3705 Notebook
Nintendo ds lite won't power up
Try two things.
  1. One of the LCD screens is making a short circuit. Disconnect them and see if the charge led turns on. If so, check these screens (or replace them)
  2. You could also have a defective Wireless PCB (the small PCB that has the black Wifi Cable connected). If that PCB is defective, loose or even missing, the DS Lite will do nothing at all
Nov 19, 2008 | Nintendo DS Lite Console
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Acer Aspire 3000 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
