Question about Compaq Computers & Internet
Thank u for the suggestion. How can i clean the
Thank u for the suggestion. How to clean the laser of the CD/DVD drive. what are the equips needed?plz help. thank u
  • 39 Answers
The method for cleaning the lens of an optical drive depends on the type of drive. If it is a laptop drive, it is very easy. Simply open the drive and clean the lens gently with a q-tip and some rubbing alcohol. If the drive in question is a 5.25" desktop drive can be a little trickier. Fortunately several companies manufacture and sell lens cleaners for use with computer CD/DVD drives. These are CDs that have soft brushes on them. When you insert the disc into the drive, the disc spins and the brushes clean the lens. Sometimes you have to repeat the process more than once to get a very dirty lens clean. If you don't have one of these but you do have a can of compressed air, you can try opening the drive and sticking the little straw inside the drive and blowing it out. If the lens is covered in a sticky sort of film (like from cigarette smoke) you may have to remove it from the computer, remove the case from the drive, and use the q-tip method to directly access the lens. (**this WILL void any applicable warranty that you may have on the drive.) Before attempting this, make sure that it's simply a dirty lens problem and not a dirty or damaged disc (by trying several different CDs and DVDs), and also make sure that the drive's controller is functional by checking the Windows device manager (right click on "My Computer", select manage, then click "device manager") to be sure that the drive is listed. If the drive is not listed in the device manager, the lens is NOT the problem. Good Luck.
SWS
*You can purchase a lens cleaner at any electronics retailer such as Best Buy or Radio Shack.
Posted on Feb 27, 2009
Crc on almost every DVD
A CRC error is a data check - cyclic redundancy check,
Either the DVD discs are dirty or scratched OR the DVD drive needs the laser lens cleaned OR the DVD drive is faulty.
If the DVD discs are scratched you may be able to polish out the scratches with a CD scratch removal kit.
Try cleaning the DVD drive with a CD drive cleaning kit to clean the laser lens.
If none of this works the the DVD drive is faulty and needs to be replaced.
May 17, 2011 | Computers & Internet
Cannot play dvd disk
Many probable reasons.
-You put dvd disk in a cd reader
-The Dvd disk is unreadable(full of scratch at the bottom)
-The Dvd reader is not identified by your computer.
1st identify what the reason is.
Then reply
Hope this helps. Thank you for using Fixya!
Apr 19, 2011 | Computers & Internet
I have an " LG DVD 5183" player which no longer plays most disks. Any suggestions?
Hi, the only real thing you can try yourself is a cd lense cleaning kit, you can buy these from most computer hardware stores and some discount shops, this may solve your problem as it will clean the laser lense and should get it working again.
if how ever after doing the above it still dont work then this points to the fact that the laser is on its way out and if this is the case then the chances are it would be cheaper to buy a new player.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated answers, thanks
Sep 02, 2010 | LG DVD 5183 DVD Player
Put dvd in and it makes clicking noise and doesn't detect it.
The Clicking sound happens, when the lens which reads the cd's,dvd's move off from its original position, this happens when the particular equipment is moved or pushed. In some rare cases, when you insert a very scratched cd, dvd. This can be solved by the particular tv company technicians, or else your warranty will be void.
Try checking whether the lens works perfectly, by playing different kinds of content ( audio cd, mp3, dvd ) etc... If any works, then your lens is working perfect. Later, try cleaning the lens using the " cd lens cleaner kit ". It will be available in any computer accessories related shop.
Thank You.
Jun 17, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
I have a trutech lmd-5702rt and it always says bad disc. i have cleaned the lens and then put a new disc and still give me same message. any ideas?
Since you have cleaned the lens and it still has the same problem. What I have seen is that the pickup laser is damaged or malfunctioning. To solve this problem you will need specialized equipment; a multimeter, a Laser Power Meter (I use the PLPM 840011), and an oscilloscope. If you do not have these pieces of equipment of do not have a background in electronics, I would suggest that you take tour device to a qualified TV repair shop and have the do the work on your device.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 06, 2009 | TruTech PVS12701 Portable DVD Player
Dvd not open any dvd
the laser has gone inside the drive... it will be much cheaper to buy a new one :)
thanks
alex
May 06, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
CD stopped working DVD is working
It's most likely a hardware problem with the drive. You can try cleaning the laser carefully, but 95% of the time the drive needs to be replaced when users experience this problem.
Feb 24, 2009 | Computers & Internet
My dvd rom wont play dvd only cd's
DVD/CD players use two different lasers. One to read DVD and one to read CD. Sounds like your DVD laser burned out. Lasers last about as long as light bulbs do.
Jan 17, 2009 | HP Compaq Presario V2000 Notebook
No Disc
Initially, try cleaning the lens using a CD ROM disc cleaner similar to those used in PC's CD ROM drives. They are normally and readily available from most computer shoppes. If the cleaning would not be corrective, pls try to manually clean by opening and use cotton buds to clean the laser/optics. it may also be worth your while to spray the insides with a can of compressed air to remove dust. Re-application of lubricant to the mechanical portion would also help.
If none of the above solves the problem, then chances are that the laser wiould require replacment. Considering the cost of repair and downtime, it might be more economical to purchase a new unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 21, 2008 | Pioneer DV-270-S DVD Player
Won't even read cd's- autostart fails...
There are two lasers, one for CDs, other for DVDs. Sounds like the CD read (and possibly Write) laser is worn out, or defective. Time for a new drive. DVDs will be fine, because they don't use the other laser at all.
Apr 29, 2006 | Toshiba SD-R6372 (SDR6372S) DVD±RW...
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
