Dvd/cd rom issues
HELLO !
I'VE GOT A DELL INSPIRON 1525 AND I HAVE A WINDOWS VISTA OS INSTALLED ON IT. MY PROBLEM IS THAT MY DVD DRIVE USED TO WORK PROPERLY AND NOW IT JUST STOP WORKING
WHEN EVER I TRY TO LOAD A DVD , IT DOESN'T RECOGNIZE IT. IS SAYS THAT THERE IS A CONFLICT WHEN EVR THE DEVICE IS TURNED ON I,E ENABLE. HELP ME OUT PLEASE. CAUSE I'VE TRIED HARD TO REPLACE THE VISTA WITH AN XP OS. IT DOES NOT ALLOW ME TO DO SO. I REALLY NEED YOUR HELP ON THIS MATTER.
THNX IN ADVANCE !!
  • 82 Answers
Try to clean the lens with a lens cleaner...if not worked then you have to change the lens...
Posted on Feb 28, 2009
When pressing F8 on a dell inspiron 1525 I can't get into setup for the advance boot options menu. I am trying to overcome a "NTLDR is missing" issue
HI,
If you're trying to boot from the DVD/CD(OS disc) try tapping on F12 to go to the boot menu and then choose your DVD/CD drive to boot from the OS Disc. From there, you can use the OS Disc to repair your computer. Here's the step by step instruction once you've booted from the OS disc:
1. Insert the Windows bootable CD into the computer. 2. When prompted to press any key to boot from the CD, press any key. 3. Once in the Windows setup menu press the "R" key to repair Windows. 4. Log into your Windows installation by pressing the "1" key and pressing enter. 5. You will then be prompted for your administrator password, enter that password. 6, Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ 7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If this does not resolve the problem, you might need to reinstall windows.
Hope this helps!
Sep 11, 2011 | Dell Inspiron 1525 Notebook
Inspiron 1525 crashed during stage 3 configuration
Follow the instructions here to repair the OS, then manually install the update that causes the issue before enabling automatic updates
http://news.softpedia.com/news/Get-Vista-Out-of-the-Infinite-Reboot-Loop-Configuring-Updates-Stage-3-of-3-0-with-Vista-SP1-78933.shtml
Apr 03, 2010 | Dell Inspiron 1525 Notebook
Install vista on my laptop can not conect to net driver missing
hello. follow the link below to get all the vista drivers for your Dell Inspiron 1525 laptop.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
since you don't have network card working on this lapto try to use some other computer and then save drivers on a flash drive or burn it to a CD to install it on your laptop.
good luck hope this helps,
Kind regards,
Amar Sondhi
Jan 24, 2010 | Dell Inspiron 1525 Notebook
I am trying to install windows service pack 1. I keep getting an error code: 0x00F0826. Can you tell me what this means and how to fix it? I am running windows vista basic. 32-bit. Thanks.
if there error appeared while windows copying files then disc OS or the DVD ROM might be faulty. Try to test first the ODD if it is faulty. Use the drivers and utilities cd from dell to test the DVD ROM. If DVD ROM reads fine the drivers disc then try the OS disc to a different computer if it can load vista files. if not the OS disc has the problem. If no issues with OS disc and DVD Rom then it might be the HDD.
Oct 22, 2009 | Dell Inspiron 1420 Laptop
Dell inspiron 1525 cd drive not recognizeing
ok what you do is go to control panel and system and then click ur driver and then install the dvd one
Aug 03, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Installing xp on inspiron 1525
The reason why xp does not see the hard drive durin setup is the ahci option enabled in the bios. you need to change the option to ata. to do that power on the system and tap f2 at the dell logo. in the bios change the stat operations to ata. the option most likely is listed under drivers. you may also have to disble flash cache from the bios. once the option is disabled hit esc and save and exit. boot from the XP cd and run the setup. at the partations screen delete the c drive and partation it according to the size you need for xp and leave the rest for vista. install XP and the drivers from support.dell.com. After XP is ready to use put in the Vista DVD once in XP and install Vista on the unpartationed space left from the c drive.
Rate if helpful.
Jun 03, 2008 | Dell Inspiron 1501 Notebook
Xp Drivers for Dell Inspiron Laptop 1525
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to find these drivers....Dell does'nt have those drivers anymore (outdated) Pls...
Apr 04, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
