Question about Mitsubishi WS-55819 55" Rear Projection Television
Bowed picture with color divergence
TV turns on and operates fine for about 10 minutes, then the picture jumps to a "bow" (taller on the right and left edges than in the center section) and the red and blue colors diverge out. When I try to manually correct the divergence, the "lines" that need to be centered seem to already be centered since they are located in teh center of the screen (i.e. not at the "bowed" edges). It sounds like others have somewhat similar problems and it is a soldered connection on the divergence IC (whatever that is). I am a pretty handy guy capable of repairing most things --- is this something I can repair? I would prefer to swap out the circuit or damaged part than attempt to resolder if the pieces are very small. Any suggestions???? thanks. Posted Aug. 1, 2007 -- Chicago Area
    President:
  • 3,130 Answers
Hi, The Mitsubishi TV set you have uses two of the STK 392-570 convergence correction IC's. These IC's can be purchased from here http://www.mcminone.com/search.asp?keyword=stk392-570&btnSubmit.x=6&btnSubmit.y=7 These are the original Sanyo replacement type IC's. No aftermarket cheapo ones. Unfortunately this board that the IC's come on is part of the main Printed circuit boards. If one was available for a replacement, it would cost in the range of about 400 bucks. The way it sound that your TV set is intermittent, is that the IC's are not bad, but need to be simply re soldered. This happens a lot with this model number or set of convergence IC's. To tell you the truth, I have had to replace these types of convergence IC's very rarely. Mostly when the set come on with bad convergence and does not change. Find a friend or a neighbor who can solder, find the black STK392-570 IC's standing up against a large metal plate, turn over the printed circuit board and resolder all of the pins, just double check all of the solder points for solder bridges. Good Luck
Posted on Aug 02, 2007
Bowing top and bottom temporary on cold TV
problem with unit is convergence--i would resolder convergence ics(they start with stk932-......)if that does not work replace them--if you need the exact part numbers email me at djstvrepair@comcast.net
Sep 15, 2009 | Pioneer SD-P50A3-K TV
Colors far out of convergence, and image is warped (bowed)
it sounds like bad solder connections on the convergence IC's if you do not resolder them right away the IC's will blow out then you wil;l have to replace them. Good luck
Larry Dillon
Aug 14, 2009 | Sony KP-57WV600 57" Rear Projection...
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Help please!
most likely a weak capacitor in the vertical deflection circuit or a solder joint.
Jul 14, 2008 | Mitsubishi VS-50705 50" Rear Projection...
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
TV-Bowing
can you post a pic of your screen so i can properly diagnose the problem as it could be either a pincushion or convergence problem. A picture would clarify it for me.
Apr 16, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Covergence and Bowed Picture Problem
can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Jan 08, 2008 | RCA P60920BL 60" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
