Question about HP Cameras
Card locked on camera
How does one unlock card on HP R967 digital camera?  Lost instuction book
  • 423 Answers
Hi there, to fix this, do this:
Remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Posted on Feb 27, 2009
Why wont my HP photosmart R967 turn on battery is new and docking station is fine but it will turn on if connected to docking station
It is likely the battery is not making contact properly or is not getting fully charged.
Check the instructions on battery connection on page 9 and confirm the lights are blinking correctly to show battery is charging.
http://h10032.www1.hp.com/ctg/Manual/c00717663.pdf
Aug 03, 2014 | HP Photosmart R967 10MP Digital Camera,...
We have an hp photosmart r967 digital camera and it says card locked cant take no pictures
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 16, 2010 | Cameras
Looking for 2 GB memory card for HP camera- R967
The R967 uses standard SD cards. You should be able to purchase them at any department, electronics, or office-supply store. You may also see them at many drugstores and supermarkets.
Dec 15, 2010 | HP R967 Digital Camera
Broken battery /memory card door. Just need a new
Sign in to ebay auction, type and click onto digital camera parts and buy a nonworking camera like yous for parts.
Nov 25, 2009 | Cameras
Will an SDHC card work in the HP photosmart R927?
No, it won't work unless HP provides a firmware update. Hp has two websites that mention what type of sd cards are compatible with your camera. One says it is and the other says it isn't. I have a HP R967, which is similar to yours. I bought an HP sdhc card from a HP website that said both our cameras could use it. I own several of this model camera, (I bought 3 to give as gifts) and the sdhc causes the cameras to display 'wrong format.' I suggest calling HP's headquarters and asking them to provide a firmware update similar to the one that HP offered for the HP M537 camera and that Casio offered for their older cameras to let them use this type card, which is what I've been doing.
Sep 29, 2009 | HP Photosmart R927 Digital Camera
HP Photosmart R967 memory card is locked...
I have an HP R927 and just had the same problem. Take out your memory card. Look on the side of the card and you will see and white "knobby thing" ... make sure it is pushed up ... that should fix it.
Sep 12, 2009 | HP Photosmart R927 Digital Camera
My R967 got a little moisture on my last fishing trip to canada, so I took the battery out and memory card and blew it with a blow dryer, it had blue stips in the monitor and I kept it on the charger for a...
actually the moisture must have entered the leads of the display...
the leads should be removed and then it should be dried so take the moisture off..
better take it to a service centre..it is risk to manually operate the sensitive parts inside and you could end up damaging the display
Jun 26, 2008 | Cameras
When i insert the memory card the camera freezes.
It sounds as if either the file allocation table or some data on the card has become corrupted.
Have you got access to another camera (friends or family) that you could try it in?
Have you got a card reader on your PC? If so, you should be able to re-format the card using Windows. (Go to My Computer, right-click on the card reader icon and select format)
Hopefully this will cure the problem. If not, you should be able to change it if it is new.
Matt
Feb 27, 2008 | HP R967 Digital Camera
Cameras Logo
178 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
