Question about C. Crane FRS AM/FM/SW Radio
LED digital not functioning on my CCradio Plus
It is imposible to tune the radio without the display. How do I fix it?
CCRadio-EP Tuner Knob Spinning and not moving tuner dial
Get a set of screw drivers of different dimensions and shapes and try each one until you find the right one.
Dec 29, 2013 | C. Crane CCRadio-EP AM/FM Radio w/ Lighted...
LED display is now blank
Had the same problume I traced it to capactor C25 100uf 16v I also replaced C32 102nf
Dec 13, 2012 | JVC Ux-lp5 Audio Shelf System
Display has gone blank so cannot tune. can this be solved without going to a repair shop? technila dab 206 digital radio
You are experiencing a backlight failure. A repair shop can repair the item (grain of wheat lamp).
Once the backlight is repaired, you will see the characters on your screen.
Apr 12, 2011 | Audio Players & Recorders
When i try to turn my radio on it says loc hoow do i unlock it?
Does your GM car or truck Radio display LOC and does not turn on? Chevrolet, Buick, Pontiac, GMC, Cadillac, Oldsmobile vehicles used a theft system to lock the radio when power is lost. This system was used from the ealy 1990's to the early 2000's.
Instructions:
  1. If your radio displays the word LOC, you can retrieve a set of factory numbers in the radio that enable you to get a backup unlock code. If the radio says INOP, you will have to leave the key in the "ON" position, or let the car run for at least 1 hour before you attempt any unlock procedure. INOP means a secondary theft lock due to too many false attempts to unlock the radio.
  2. Looking at the face of your GM Delco radio, hold down the preset buttons 1 & 4 OR 2 & 3 (Depending on year and model) for approximately 10 seconds or until a set of 2 or 3 numbers comes up on the display. Write the numbers down.
  3. Next press the AM / FM button. A new set of 3 numbers will now show. Write these numbers down. You will then need to call a 1-800 phone number with these numbers to get the unlock code. There are many sites on the internet that can get it for you- for a small fee. Or, try calling your local GM Dealer and ask for them to do it. Many times they will do it for free. It only takes a minute.
  4. Once you have the unlock code, enter it by pressing the MIN button until the display shows the last 2 digits of the unlock code, then press the HR button until the first 2 numbers or shown. Then press the AM / FM button to enter the code. The radio will now display SEC, and normal function is restored.
Also, its possible that you need RESET your GM Radio; this is the procedure: While performing maintenance on your car, you may disconnect the radio from the battery in your GM vehicle. GM cars contain Delco radios that are protected by Theftlock, which locks the radio after it has been disconnected from a power source. Iit can only be reset and unlocked with a car-specific security code. Identifying the security code for your GM vehicle is the only way to reset the car radio and disable the Theftlock protection device.
Instructions:
  1. Turn on your car. Your Delco radio will show "LOC" in the LED display.
  2. Press and hold down both the second and third preset buttons. Hold these buttons down for at least six seconds.
  3. Write down the two- or three-digit code that appears in the LED display.
  4. Press the AM/FM button on the radio.
  5. Write down the next two- or three-digit code that appears in the LED display. You should be left with either a four- or six-digit number. Turn off your car.
  6. Call the Delco radio automated customer support line at 1-800-537-5140.
  7. Press "1" and then press the pound sign. The automated voice should respond "Invalid code, try again."
  8. Enter the number 139010 into your phone and then press the "*" sign.
  9. Enter the four- or six-digit number you wrote down from Steps 3 and 5, and then press the "*" button.
  10. Write down the four-digit code given by the automated voice.
  11. Turn on your car. Enter the Delco unlock code using the procedure outlined by your GM owner's manual. Normally, the unlock code is entered with the "HR" and "MN" buttons on your radio.
  12. Press the AM/FM button. If you have entered the code correctly, your LED display will read "SEC" and the radio will be unlocked.
Also can check your Does your GM car or truck Radio display LOC and does not turn on? Chevrolet, Buick, Pontiac, GMC, Cadillac, Oldsmobile vehicles used a theft system to lock the radio when power is lost. This system was used from the ealy 1990's to the early 2000's.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Instructions:
Also, its possible that you need RESET your GM Radio; this is the procedure: While performing maintenance on your car, you may disconnect the radio from the battery in your GM vehicle. GM cars contain Delco radios that are protected by Theftlock, which locks the radio after it has been disconnected from a power source. Iit can only be reset and unlocked with a car-specific security code. Identifying the security code for your GM vehicle is the only way to reset the car radio and disable the Theftlock protection device. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Instructions:
Also can check 1999-Pontiac-Firebird-Owners-Manual (page 163), there are several information about to lock and unlock.
Hope this help (remember comment and rated this).
Apr 06, 2010 | 1999 Pontiac Firebird
GM Radio Locked but will not display codes by pressing 1&4 or 2&3
Instructions:
Instructions:
Hope this help.
Mar 18, 2010 | Car Audio & Video
Radio without remote
Press Function button at front of unit until display shows Tuner, and press Preset + / Preset -
If you want to listen Non-Preset stations, press << / >> keys of remote to tune a station. That's the procedure.
If built-in remote in your mobile have above said << / >> keys, you can tune station frequency.
Nov 10, 2008 | Audio Players & Recorders
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
No Sound
try plugging it the headphones in and out a few times,problem could be bad connection it that connector
Jul 10, 2008 | C. Crane FRS AM/FM/SW Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
C. Crane FRS AM/FM/SW Radio Logo
321 people viewed this question
Top C. Crane Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a C. Crane Audio Player and Recorder Expert? Answer questions, earn points and help others
