Question about Epson Stylus Photo R300 InkJet Printer
Epson R340 printing
My printer is about 2 and a half years old. it is out of waranty. It is no longer printing even with new cartridges. I get a message:
"consumer parts have reached service life. see service center"
What does this mean and can I do this myself?
Thank you,
Jose Songco
Only one of six original ink cartridges in my R340 and printer refuses to print calling for replacement. How to override its program an continue use other inexpensive inks? Thanks for help
you will not be able to override the program. some replacements do work. i suggest you remove the replacement ink, turn off your printer, turn it back on and put back the replacement cartridge. if it still does not work, the replacement might not be as compatible. get another brand. the chip included on the cartridges might be busted.
Jun 19, 2010 | Epson Stylus Photo R340 InkJet Printer
I would like to print direct to a DVD and a CD on a epson stylus
download new drivers for the R340 andthere will also be printing software attached to the drivers
Jan 02, 2010 | Epson Stylus R340 InkJet Photo Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Epson Stylus Photo R340 Faces in photo are printing day-glo green
Possible printhead or driver issue.
Are you using Adobe photoshop? Please try to print also using a different application to isolate the issue.
Make sure that you are using correct epson cartridges.
Please print a nozzle check pattern. If you see gaps, missing colors or missing lines on the pattern, clean the printhead using the driver.
If the nozzle check pattern printed out successfully, please trash and re-install the drivers. The driver is available on epson.com
Apr 29, 2009 | Epson Stylus Photo R340 InkJet Printer
Screen says "service required" Printer will only turn on, that's it.
Its Epson design. It means it already reach it maximum reliable printing service. But you can extend its service using Epson resetter. Its a third party software utility program. It will reset its counter to zero count again. Counter resetting is on the printer itself not in the ink cartridge.
Leave a message
Apr 15, 2009 | Epson Stylus Photo R340 InkJet Printer
Epson r340 ink cartridges not recognized
god pm my printer ako na epson r230 ang problem niya ay walang lumalabas na output paano irepair yong
Feb 13, 2009 | Epson Stylus® Photo R340 InkJet Printer
Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Mar 08, 2008 | Epson Stylus Photo R340 InkJet Printer
Reconfigure ink to print setup?
Actually, epson printers needs all the inks for it to print. The print heads on epson are fixed thath is the reason why they need to be primed with inks when printing to prevent print head damage.
Feb 12, 2008 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
125 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
