FixYa.com
Tags:
NEC /Torisan Swan 6x EIDE CD-Rom Module  DVD Drive
Problem with WD 7197 and NEC 6x CDROm
By 2Pansy - usenet poster
I'm having problems with my NEC 6x CDROM drive. It keeps locking up
my Win95 system. Sometimes all I have to do is click on my computer,
and it will lock up. If I disconnect the CDROM, it works fine. It
happens about 70% of the time. It will also sometimes lock up on boot
up (and when I try to access it).
Termination is setup OK. SCSI ID's are setup OK. Western Digital
tells me that Win95 has a problem with 6x CDROMs, which I'm not sure I
believe. Anyone have this combination working all the time? Thanks
much!
BTW: Everything shows up as working under the devices screen in System
Setup.
System:
Tyan Titan III with 512k PB Cache
P-133 CPU
IBM Ultrastar XP 2.1gig Wide SCSI
Seagate Hawk 1.05gig Fast SCSI
NEC CDR-512 Internal 6x SCSI CDROM
Matrox Millenium w/ 2megs
Western Digital 7197 Fast/Wide SCSI Controller
USR 33.6 Internal Modem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Geez, I don't know about the Win95 incompatibility. I'm even running
fine using the Win95 Nashville 4.10.999 BETA. My reseller *did* have
to send two faulty units back, though, which was really peciliar.
Mine has to be okay, because I just ran it with my CD-R, and a disc
dupe will take a lot from a system, I suppose. Perhaps a firmware
upgrade? Please let me know if you find out, because for now I can
only do Digital Audio extractions at 1x (ridiculous for an expensive
6x drive, eh?)
Best Regards,
Al Abadilla <
(David Forehand - Medford, OR) wrote:
...I'm having problems with my NEC 6x CDROM drive. It keeps locking up
...my Win95 system. Sometimes all I have to do is click on my computer,
...and it will lock up. If I disconnect the CDROM, it works fine. It
...happens about 70% of the time. It will also sometimes lock up on boot
...up (and when I try to access it).
...Termination is setup OK. SCSI ID's are setup OK. Western Digital
...tells me that Win95 has a problem with 6x CDROMs, which I'm not sure I
...believe. Anyone have this combination working all the time? Thanks
...much!
...BTW: Everything shows up as working under the devices screen in System
...Setup.
...System:
...Tyan Titan III with 512k PB Cache
...P-133 CPU
...IBM Ultrastar XP 2.1gig Wide SCSI
...Seagate Hawk 1.05gig Fast SCSI
...NEC CDR-512 Internal 6x SCSI CDROM
...Matrox Millenium w/ 2megs
...Western Digital 7197 Fast/Wide SCSI Controller
...USR 33.6 Internal Modem
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
Hi!
I have the same problem. The best you can do at this time is:
1)Update the WD-7197 bios to ver. 1.07 from their web site
2)Update the Driver to ver.3.0 from their web site
3)Disable "auto insert notification" under cd-rom/system/control Panel
4)Keep the cd out of the CD-Rom when you are done with it
Since we have almost identical system, follow those procedures should keep the 6xi
work under 95 most of the time.
In the mean time, don't expect WD solve the problem soon! They promise me they will
fix the problem last November. If you can return the card now, do it!
Good Luck!
M. Young
Solution #3
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
Assuming that you are not running any config.sys or autoexec.bat drivers for
the CD-ROM, and only the 32-bit WD SCSI driver, try turning off the Win95
autoplay feature. It's problematic.
Mitch Regenbogen, Brooklyn, New York,
"Knowledge is Good."
Can you Help with these DVD Drives problems?
DVD Drives
Cant play DVD video
I have a LG DVD writer model... Answer This...
DVD Drives
DVD drive not running specific...
my dvd drive, on a vista home... Answer This...
DVD Drives
SOLSTAR DVD PLAYER, DVD 15SS
The DVD Player did not have a... Answer This...
DVD Drives
I have a problem with DVD-ROM
Good Night My name is Sergio I... Answer This...
DVD Drives
My Acer 5610Z Laptop DVD Drive...
I was burning CD's on my DVD... Answer This...
Repair Service
Find DVD Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
