Question about Milwaukee 0730-22 V28 6-1/2" Circular Saw Kit
Milwaukee 6390 dead
Hi - I have a Milwaukee model 6390 7 1/4" circular saw. It just stopped working. It is getting power to and through the switch. There is 110 volts at the brush holder. However, it is dead!Please help
  • nkbay Mar 01, 2009
    Hi - All parts working perfectly. Voltage at Motor Housing Assembly is 120; voltage at brush holders is 19. Commutator runs
    smoothly
  • Anonymous Mar 26, 2014
    I need to find brushes for a direct power circular saw dpb212csw
  • 2,176 Answers
I dont know how old the tool is but when I worked on them it was notorious for exploding the commutator and damaging the brush holders, hopefully yours didn't do that. You have voltage at both brush holder then I would remove the brushes (UNPLUG TOOL FIRST) making sure they are not sticking in the tubes and while they are out rotate the tool by hand and look for any noticable difference in the commutator bars. Check all the connections from the field to make sure the circuit is complete like it sounds that you have done and if so that just leaves the two items I mentioned. Let me know if I can help further.
Posted on Feb 27, 2009
  • David Ford
    David Ford Mar 03, 2009
    Instead of checking voltage check for continuity thru each leg of the field and from the switch to the wires that feed the field. Other than that are the brushes stuck and if not you have me stumped.
MILWAUKEE CIRCLE SAW MODEL 6470-21 serl#849ad13360234
either installed wrong --or wiring short ----if you did repair re open saw and check wiring ,connections and install of component if done by shop return for them to fix
Sep 21, 2016 | Milwaukee tools Milwaukee 6470-21 10-1/4"...
12" Milwaukee. Why does it lose power after it has been run for awhile?
Assuming there isn't some other mechanical problem or the saw isn't being overloaded, most circular saws have motor brushes that can wear out after extended use. These brushes are usually replaceable. When the brushes are worn, they will not deliver sufficient power from the motor stator to the armature (the part that rotates).
Here is a link to a parts supplier. Find your model number and look for brushes.
http://www.ereplacementparts.com/milwaukee-circular-saw-parts-c-131_5128.html
Aug 29, 2015 | Saws
I have a Milwaukee circular saw, 6365, and am replacing the switch. Need a wiring diagram!
Scott,
What is the serial number on your saw? I need that to make sure I get the correct info for you.
May 30, 2015 | Milwaukee Tool Saws
The model number is Milwaukee 26 30?20 it needs a new switch it up
Lay the saw on its side with the screw in the handle facing up and battery removed... remove screw along the two half's of the saw.... you will see a seam where the left and right side meet... once screws are removed ( make sure you remember what screw goes where, there may be different sizes) lightly pry apart incase you missed a hidden screw, I'd so remove it... disconnect old broken switch and install new one... may have to order the part in
Dec 23, 2013 | Saws
Have relatively new (month old) milwaukee 2630 circular saw. Worked fine for about a dozon cuts, and then just stopped mid cut. Tested batteries on other tools - they work fine. Is there an internal...
If it just quit working and it is that new I recamend that you take it back and demand a replacement they are a good tool and I'm sure that the will stand behind there product hope this helps Merry Christmas
Dec 05, 2017 | Milwaukee 2630-22 18-Volt 6-1/2-Inch...
I have a Milwaukee circular saw model 6365. It still cuts fine, but it squeals loudly (like a little girl) when running. Sorry, couldn't help myself. Seems like the motor bearing(s) need lubrication. ...
You can try to lube the bushings, but they will always start to squeal again. I have tried just about everything, 2 cycle oil works good, wd-40 is a little thin, blaster works ok for a while, reg 3m oil forget it, motor oil, no, white grease, hard to get in there, axle grease, yes, but you have to take the bushings out. The oils, you don't have to take the saw apart. Hope this helps.
Aug 18, 2010 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
I was drilling and it just stopped working, is there a safety switch or something
If there wasn't a burnt smell signaling burning out the drill then you should be able to just recharge the battery
Jun 20, 2010 | Milwaukee 2690-24 18-Volt Hammer-Drill,...
I need to replace cut electric chord on saw 6390-20
I would go to Milwaukeetool.com and download a breakdown for this tool. But all you have to do is remove the screws holding the handle assembly to expose the switch area and cord. I think they are a T-20 Torx, after removing the half make a note of the wiring before removing the old cord. trim the leads using the old cord as a guide and reinstall. what you want to do is when you reinstall the screws back them until you feel the first thread so you don't rethread it. These are thread forming screws and after a time they will strip out the threads. It is really quite simple
Mar 27, 2010 | Milwaukee Tools Circular Saw 6390 - 20
I need a wiring diagram for a milwaukee heav duty circular saw
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
Apr 08, 2009 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Milwaukee 0730-22 V28 6-1/2" Circular Saw Kit Logo
232 people viewed this question
Top Milwaukee Saws Experts
Navin Sharma
Navin Sharma
john h
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
