Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
By Chance have you reset the wireless router?
Thanks,
Chris
