Question about Gateway 614GE PC Desktop
Just a simple question
I would like to know if on a Gateway 614ge where the graphics card is located and if i can install a new one on the tower
    President:
  • 2,653 Answers
Open the desktop and wherever the monitor plugs into just follow that on the desktop. It will either be onboard video (on the motherboard) or a separate card.
Either way you can always change the video card.
You just need to make sure it's AGP 8x
That's what your board supports.
Best of luck!
Posted on Feb 27, 2009
Installed a new graphic cards for Gateway DX4710-UB801A, it works for a day, but the next day, it wouldn't turn on, the power supply is not running.
Pull the new graphics card out to see if the power supply will start up, if no change, you will need a new power supply module.
May 11, 2012 | Gateway DX4710-UB801A (L-1015700R) PC...
When i turn my ATXAEG on the green light comes on but will not do anything
Sub out your ram one at a time and test, if you find one bad stick it will in some cases shut the computer down, next unplug hard drive and test, if no change you may have a bad video graphics card, unplug if possible! if system come back you know the graphics card is the problem, if none of these help the motherboard is the likely issue.
Mar 19, 2012 | GATEWAY DESKTOP FX84015E 293GHZ 8GB RAM...
Horizontal lines come in the monitor I replce the monitor thinking thats the problembut no the horxontal line keeps coming back do I need to replace the tower?
There is a possibility of your system RAM being faulty as the Nvidia on board graphics card uses this to display the picture.
You can one fit a PCI Express graphics card which will fix the problem or two replace the faulty RAM module.
Hope this helps.
Jul 10, 2011 | Gateway GT4016 Desktop PC
Im trying to disable the on board graphics card so i can install then new on i just bought. i have a gateway GT4024 and the onboard graphics card is an ATI Radeon Xpress 200 series
Your board has ATI integerated graphics, no need to remove. You would upgrade by adding a PCIe express card in slot. Do you have such a card? If you need installation instructions, let me know at "add a comment"
Dave
Apr 06, 2011 | Gateway GT4024 PC Desktop
Ive looked and looked and my gf really needs to upgrade her graphics but i cant find a solution to this she is using a sx2803 gateway and its a mini tower and we need something to fit in it please anyone...
Since the Gateway SX2803 is a mini tower, you will most likely want to use a 'low-profile' video card. These cards are built short, so they can fit in smaller cases. You can find a fair selection here: http://bit.ly/eOfvmg
As for what /type/ of card, you should be able to determine what type of expansion slot(s) your computer has from the user manual, or by opening the case. I know the Gateway SX2803 25e has a free PCIe x16 slot.
Mar 30, 2011 | Gateway Desktop / Intel Pentium Processor...
I tried to upgrade my 614GE Gateway from 512 Mb to 2 Gb, the system indicates I only have 960 Mb, I orded another set and now the system will not turn on, I swaped the old and new now I have 1.43 Gb, what...
First make sure you have the right modules (DDR 1 or 2 and the speed 400mhz or something similar).
Then when you insert the new modules, does the computer beep?
Of not then you ok, if it gives you al log beep there is a memory error.
And if you have a integrated GPU it takes some memory for its own use.
Or maybe the computer cannot handle 2GB.
Hope this helps!
Mar 01, 2011 | Gateway 614GE PC Desktop
I added a new video card and the monitor wont come on
1) Did you plug the monitor into the graphics card?
(Hey, happens! Sometimes in our zealousness to see what that baby will do, we mess up a little)
2) Did you install the Drivers? First?
These will be on the installation disk that comes with the graphics card.
Recommend installing the software from the disk FIRST, then turn the computer off, unplug from power, install the graphics card.
3) Does the graphics card require additional power?
Some graphics cards will not receive enough power, from the graphics expansion slot they are inserted into.
[Gateway GM5084 uses a PCI Express x16 slot, for best graphics.
http://support.gateway.com/s/PC/R/1009054/1009054nv.shtml
(Left-click on Specifications]
Some powerful graphics cards require additional power cables from the Power Supply.
Post in a Comment.
Sep 29, 2010 | Gateway GM5084 PC Desktop
I need to find a replacement video card for my E-3400 . The cards that are readily available have the long flange for mounting. This one has a mounting flange that is about two inches wide. It also only...
The Gateway E-3400 Desktop computer, uses a Low Profile, ATI Rage 128 Pro graphics card, according to ATI Support.
It is an AGP 4X graphics adapter card.
(AGP - Accelerated Graphics Port)
Made around June 20, 2000.
This is the E-3400 Mid Tower System Manual,
http://support.gateway.com/s/manuals/servers/eseries/8505957.pdf
,(From Gateway. It's a PDF file), in case you do not have this manual anymore.
I see what you mean about the mount bracket.
REAL SMALL! The video card is a Low Profile card, but the mount bracket is Unusual!
From searching Gateway Support,
1.Looking through their graphics cards,
2.Looking for an ATI Rage 128 AGP 4X graphics card, that is Low Profile, and has the bracket I believe your computer uses,
(Based on the above E-3400 Mid Tower System Manual, and the photos on this website,
http://www.mayoousa.com/osc/catalog/product_info.php?products_id=989
Image 4),
4.I believe this is the graphics card you need from Gateway,
http://support.gateway.com/s/VIDCARD/ATI/6001587/600158703.shtml
The only way to be - Sure, is to physically look at the Product number on the video card you have now.
If this number does not match up, please come back, and state so.
I'll give you the link to the Gateway Support page, with all of the AGP video card product numbers, so you can match up to the correct one.
Availability? I don't know.
You'll have to contact Gateway yourself. They have Select Retailers.
What I do know.
The link above, where I stated I looked at the back of the Gateway E-3400, to see close detail of the VGA connector, and mount bracket of the video card.
(MayooUSA)
They're selling the entire tower unit for $24, and shipping is $20 in the USA.
Not advertising for this website. We don't do that here. I'm just stating what I found.
Nov 10, 2009 | Cars & Trucks
Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to http://support.gateway.com/support/default.aspx input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Sean
Mar 16, 2009 | Computers & Internet
I've added a new graphics card and now get no sound.
I SUGGEST YOU READ A MAGAZINE CALLED CPU [COMPUTER POWER USERS]
FROM 11/2008 TO PRESENT ISSUES
ROD
Mar 12, 2009 | Computers & Internet
Gateway 614GE PC Desktop Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
