Question about JVC KD-G430 CD Player
Cds wont play
No problems with picking up radio, but code 000-zaa0 appears on the front panel flashing and will not play cd's!! Anyone had the same problem?
  • Anonymous May 07, 2009
    Where is the pinhole?
Have you tried resitting? take face plate off you will see a pin hole. press with a needle, toothpick... press one time. its worth a try
Posted on Apr 30, 2009
How does the display on my CD/radio work?
Sorry to hear the display is blank even though the cd radio appears to function. The display is usually an LCD with back panel lights that makes the characters visible. Most likely the small rice globes behind the panel are blown. Usually needs some sort of desoldering and resoldering to replace. If you can take the player out from the dashboard and take it to the local audio repair shop you will save quite a bit of money to get this fixed.
I am assuming your CD radio looks something like this.
http://www.beckerautosound.com/pdf_guides/om43-4462.pdf
Jul 30, 2014 | Porsche Boxster Cars & Trucks
2007 camry radio
hey, that sounds like wiring for sure, if your cd player is working fine and its just your speakers? then yes that would be a wiring problem, theres a bad wire somewhere in the system. either find out yourself where the bad wire is or bring it to someone who know how to repair those types of problems. good luck!
Feb 15, 2014 | Cars & Trucks
Im still waitin for someone to help me with unlockin my stereo on my 98 Lumina
to unlock radio.if you dont have no code wrote down.try this procedure. first write down any three or four digit number from 000 to 1999 and keep it in a safe place separte from the vechicle. turn the ignition to ACCESSORY or RUN. turn the radio off. press the 1 and 4 buttons together. hold them down until - - - shows on display. next you will use the secret code number which you have written down.press MN and 000 will appear on the display. press MN again to make the last two digits agree with your code.press HR to make the first one or two digits agree with your code.press AM FM after you have have confirmed that the code matches the secret code you have written down.the display will show REP to let you know that you need to repeat press MN and 000 will appear on the display. press MIN again to make the last two digits agree with code.press HR to make the first one or two digits agree with your code.after that repeat press AM FM and this time the display will show SEC to let you know that your radio is secure. the the indicator by volume control will be flashing when the ignition is turned off.IF ALL FAILS DEALERSHIP NEED TO RESET RADIO CODE..
Mar 11, 2013 | Cars & Trucks
Battery disconnected radio code not known renault megane model 22dc259/62t serial no 7700434422tn754
The code for your radio is 2 2 7 3
Please do leave a vote for the solution to show to others that the code is correct.
I have a very restricted amount of software for generating free codes but for anyone else needing a cheap radio codes for other Fords and many other models I can recommend this site.
Thanks for using FixYa.
Aug 23, 2011 | Car Audio & Video
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
Cant pick up any radio stations after battery was changed
probably need the anti-theft code to get the radio working again
Jul 15, 2017 | Sony CDX-M600 CD Changer
Radio won't play, display shows only a code of FB-1
Maybe the code error are F 61 for a panasonic sistem that code means bad audio amplifier
Jan 20, 2009 | Audio Players & Recorders
Car stereo displays 000ZAA
000ZAA:
remove front panel and press reset button with ballpen
Jan 10, 2009 | Car Audio & Video
Code OCER AND WILL NOT PLAY
Hi, This also happened to me, and what I did was, I reset the radio and wala it worked fine. Hope this works for you.
Nov 23, 2008 | Kenwood KDC-135 CD Player
Kd-g322 error code query
I unpluged all the wires for one more time and it works again!!!
I think the problem is that one or some wires are damaged because they are pressed between the unit and its case. I also shaked them up and down and for now, it is ok. Try it!!
If this works for more than one day, I' ll let you know...
Jan 03, 2008 | Car Audio & Video
JVC KD-G430 CD Player Logo
170 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
